Speedometer/Odometer Calibration
I've just upgraded to bigger treads with the new suspension (33x10.5xR15 vs. stock 235/75/R15) which has predictably changed the accuracy of the speedo and odometer.
Does anyone know if you can replace the sprocket on the speedo/odo cable to reflect the change in tire diameter so that both will be accurate again? Is it even possible to do?
Thanks,
-dogboy- '87 FJ60
