Speedometer delete t case cap? (1 Viewer)
Connecticut
Replaced my speedo cable as the old one broke. This seems to just make it without room to spare and as it is pretty well stretched I think it is leaking. The gauge is still having issues as it was before the old one broke, so for the time being I’m looking for a cap to blank it off.
Does anyone know what size/pitch these threads are? Is it BSPT like the engine block?
Thanks!
I cut the old cable, used the end piece and siliconed a quarter in there and screwed it on, might of been a nickel.
I tapped mine and put in a 3/4 npt pipe plug.
And now that I just taking and seeing this pic, I gotta go see if that really is a crack there.
I grabbed an M20 nut and it’s too small/ too corse. I was able to try it on a parts T case housing I had stashed away. I’m thinking it’s an M22 fine thread, so I am going to find a cap nut in that size and give it as shot. I’ll report back.
Clearly not the right pitch
I never noticed but the parts T case, which is missing just about everything else, had this busted speedo cable extension. Does anyone still make these? It measures a bit under 22
If that doesn’t work… the nickel does fit with a little filling
Nevada Speedometer, Sparks NV can make any cable needed. They've made a few T-case shorties for me. Also I think Marin Crawlers, BTBpro.com has them also.
Nevada Speedometer 878 Marietta Way Sparks, NV Auto Repair - MapQuest - https://www.mapquest.com/us/nevada/nevada-speedometer-10702428
Found my order receipt
Bolt Nut Metric Thread M22X1.5 M22 x 1.5 Female Banjo Cap Plug Plated Steel https://a.co/bJ7m02m
For those of us who buy everything on Amazon.
Trail Gear and Advanced adapters make a Toyota speedo extension cable. But they are more than a nickel...
