Speedometer correction by T-case gear change (1 Viewer)
Dallas, TX
I just regeared from 4.30 to 4.10, so obviously my speedometer is 2mph off. What I do know is, I have a 20 teeth speedometer gear and I will need a 19 teeth one to match my axle ratio and tires. I looked through the parts catalog and see that the VZN85 uses a 19 teeth speedo gear. Does this fit on all the other runners (that has an automatic) of the same era regardless of engine? I thought about using a 18 teeth also, but that'll make the speedo slightly fast. I don't want that! Anyhow, if the speedo gears in the 90-95 mini truck/runners mix and match, does anyone know where I can find these cheap (other than junk yard or dealer)? I would love to have an accurate speedometer again :)
I'm still with stock tires. I went with 4.10 because there isn't an aftermarket 4.30 7.5" gearset, but also the idea is to get better gas mileage :)
after spending time looking through the parts catalog and seeing that the speedo cable housing is the same on all the runners, I'm fairly certain that the speedo gears can swap over... I just want to make sure and be assured it will work before I spend money on a new gear
so if anyone has swapped their speedo gears, please reply!
I think the 4 cylinder/5 speeds had a 6/18 output to speedo cable gear set... I do not know if you can swap just the one gear... What you should look at is the output gear, to see if they are all the same between the different engine/trans combos...
Good luck! FYI I have not heard of anyone doing this, at least not to completion...... :cheers:
just to make this clear and avoid a misunderstanding, I'm referring to my previa van, which happens to use a 7.5" 3rd member... so obviously the mini truck 7.5" IFS stuff fits.... I wish this rig had a 8" ring gear, which would make things easy as nitro does have the 4.30 8" gears
interesting enough, the previa uses the same 20 teeth speedo gear as some of the 2nd gen runners, which is what led me to posting this thread :)
so.... for all intents and purposes, just assume we're talking about a 2nd gen runner speedo :D
ugh, browser fail... let me post this again so that its legible
why can't I edit posts? :mad:
I actually see several gears listed for the 2nd gen runners in the parts catalog...
there's at least five different *drive* gears, which is a nightmare to change out... but, as far as the *driven* gears (the ones I'm inquiring about in this thread) for the auto trans:
16 teeth... 6:16
17 teeth... 6:17
17 teeth... 17:5
17 teeth... 17:6
18 teeth... 6:18
18 teeth... 18:6
19 teeth... 19:6
20 teeth... 20:6 (same as non-S/C previa with 4.30 axle)
for the manual trans:
26 teeth... 26:11
27 teeth... 27:11
15 teeth
19 teeth
29 teeth... 29:11
30 teeth... 30:11
31 teeth... 31:11
32 teeth... 32:10
32 teeth... 32:11
34 teeth... 34:10
34 teeth... 34:11????
there's actually a whopping EIGHT speedo drive gears for the manual trans... no doubt it is also difficult to change out
well seeing as nobody has really done this, I guess I'll have to take the plunge and give this a try... the speedo gear I need is back ordered and will take a couple of weeks to get in
thanks for reminding me why I like this forum a lot more than the other mini truck forum that don't seem to be as cordial :)
oh I will... and I will post a list of the speedo gears part numbers once I determine this works
I will need some help though as I'm not familiar with runners :)
if successful, this is a more simple and cheaper solution than using those silly speedo correction boxes ;)
VZN85 mini truck 19 teeth speedo gear ordered... now I'll have to wait 2 weeks for this to come in :frown:
As long as the speedometer output for the gear is off the case then yes, excluding of course two particular things here.
A 2wd-Auto output will not work b/c of the way the output shaft is setup versus a transfer case's.
You match things to be electrical-feed to electrical feed as well as mechanical to mechanical.
The reason they'll interchange so readily is b/c of the eccentric offset of the shaft the gear attaches to.
**My R-150 I swapped into my '95 had a 31 tooth, so those other part #'s are respective to the manual transmissions like you posted.
They're all easy to swap out. Look where the speedo cable attaches and undo the coupler. Then grab a (12mm IIRC) 6 point socket and undo the nut holding the fingertip shaped piece to the slot on the side of the speedo-gear assembly. Twist slightly while pulling outwards and it'll pop right off.
PIc borrowed from pirate showing the electrical version, the nut I described as well as the fingertip plate.
Great topic, Mods might want to add this to the FAQ. :wrench:
thanks for the reply... I'll make this thread "FAQ worthy" once I get my new gear in, swap it, take pics, and then post the huge list of toyota part numbers... I haven't seen anyone else post about the gears, so I guess I'm one of the few adventurists :D
it turns out that my A46DE (RWD previa trans) has a cable speedo housing that goes into the tranny's extension housing, BUT instead of a cable that screws onto it like you would expect, an electric sensor screws into it!... pulling the thing out is just like what you described from what I saw in the FSM... a 10mm bolt, remove the little metal plate, then the gear assembly pulls out... I don't expect to need to separate the sensor from the gear housing
the later year previas uses the A340E (or A340F), and it has a "one piece" sensor like the one in the pic you posted
anyway... just extraneous info that won't concern any of you :D
got the gear in today... was surprised it came so soon actually... so I put it in this afternoon, fits PERFECTLY
had a little trouble getting the whole assembly off the tranny as the o'ring "glued" itself to the tranny... after fighting it for a bit it came out
what's interesting in the A46DE is, there's no clip at the bottom of the tube to hold the gear in place like you expect in the pre-93 hilux, it just slides right in!
I'm going to go test drive in a bit and will post pics tonight... I'll try to post those part numbers soon also
As promised here are the pics...
Here is the new gear (it came with a new o'ring too! :D):
This is the VSS1 unit itself... ignore the sensor, the gear housing is actually a cable speedo housing (similar to the mini trucks) and the sensor screws into it on the A46DE... weird!
I didn't notice the little gold linkage piece in the middle of that pic oriented the wrong direction when I took the pic.... in any case, the small end goes into the gear housing.... pretty obvious once you have it apart. I don't know if the mini trucks has this piece though
New and old driven gears side by side:
It's hard to see in this pic, but you can barely see the speedometer drive gear.... it's a giant worm gear inside the tranny's extension housing. If you don't know which driven gear you need, you can count the teeth in the drive gear. I counted it just for grins and it was indeed 6 tooth. Sorry, it was hard to take this pic.
The new gear just pops right in and it went into the extension housing like warm butter!
What's interesting is, there's no clip to hold the gear in place like it is on the hilux/surfs... Another 10 cent part unneeded I guess since the gear has no where to go as you can see in the previous pic... there's a giant aluminum stopper to keep the gear from flying out in the A46DE. :)
You can see the actual hilux/surf speedo gear unit here (notice the clip):
Mechanical Speedo Correction Box - Install with Pics - YotaTech Forums
Accurate speedometer again all for a little over 20 bucks! This is WAY cheaper than either the electronic or mechanical correction boxes which costs around $100. Time spent to put this in is probably less than the more expensive alternative.
I drove my van around and went by one of those speed check signs, and it is reporting what I was expecting... the speedometer is accurate! I still need to get it GPS checked but I'm confident it's within 1/2mph accurate :steer:
Hopefully this weekend I will post a list of speedo gears so all of you can benefit from this cheap fix like I did :cheers:
Like I said, it went in like warm butter... I did rotate it back and forth a bit as I was sliding it in, in order for it to mesh up... but the only thing I had to fight was the friction from the o'ring itself
I spun the wheels while the van was still in the air up to 40mph and confirmed it was working before I put it back to the ground. :)
Oh yeah, I forgot to say that the tranny shifts at the correct speeds again (since the ECU sees the VSS1 signal first before the speedo does)... in fact it seems to shift at lower rpms than it used to, which is better for gas mileage in most cases :D
NOT RESPONSIBLE FOR INACCURACY
Automatic RWD speedometer driven gears for cable speedometer:
Code:
[B]33403-69175[/B]         16 tooth, 6x16 mark          VZN85/VZN90
[B]33403-69185[/B]         17 tooth, 6x17 mark          RN90/VZN120
[B]33403-69195[/B]         18 tooth, 6x18 mark          RN8*/RN90
[B]33403-69135[/B]         19 tooth, 6x19 mark          VZN85
[B]33403-29235[/B]         20 tooth, 6x20 mark          RN12*/VZN85/VZN95/TCR1*
[B]33403-39185[/B]         17 tooth, 5x17 mark          VZN95/TCR11
Automatic RWD speedometer driven gears for electric speedometer:
Code:
[B]33482-39405[/B]         16 tooth, 6x16 mark          VZN90
[B]33482-59015[/B]         17 tooth, 6x17 mark          RN90/VZN120/TCR1*
[B]33482-59025[/B]         18 tooth, 6x18 mark          RN8*/VZN85
[B]33482-29205[/B]         19 tooth, 6x19 mark          VZN85
[B]33482-39415[/B]         20 tooth, 6x20 mark          TCR1*
[B]33482-39375[/B]         17 tooth, 5x17 mark          VZN95/TCR11
Manual RWD speedometer driven gears for cable speedometer:
Code:
[B]33482-39145[/B]         15 tooth, unknown mark       RN80 (P195/75-14 tires)
[B]33482-39305[/B]         19 tooth, unknown mark       RN80
[B]33403-39125[/B]         26 tooth, 26x11 mark         RN80
[B]33403-39135[/B]         27 tooth, 27x11 mark         RN80 (P195/75-14 tires)
[B]33403-39245[/B]         29 tooth, 29x11 mark         VZN85/VZN90
[B]33403-29105[/B]         30 tooth, 30x11 mark         VZN85/VZN90
[B]33403-19245[/B]         31 tooth, 31x11 mark         RN80/RN90
[B]33403-19255[/B]         32 tooth, 32x11 mark         RN121
[B]33403-29145[/B]         31 tooth, 31x10 mark         VZN85
[B]33403-29125[/B]         32 tooth, 32x10 mark         VZN85/VZN95
[B]33403-29225[/B]         34 tooth, 34x10 mark         VZN95
Manual RWD speedometer driven gears for electric speedometer:
Code:
[B]33403-39365[/B]         30 tooth, 30x11 mark         VZN90
[B]33403-39345[/B]         31 tooth, 31x11 mark         RN8*/RN90
[B]33403-29315[/B]         32 tooth, 32x10 mark         VZN85
[B]33403-39375[/B]         34 tooth, 34x10 mark         VZN95
can you please change the thread title to something more appropriate? that way if people search it will be more obvious :)
I didn't expect this to take a few hours to gather the info and present it legibly, so I'll work on the 4WD stuff tomorrow
