Speedo Electrical White Smoke Nightmare... (1 Viewer)
NYIronPig
YES I have a problem...
New York
Was changing my Speedo out (old one not working) and when I went to put it back in, sparks & white smoke. Yes I didn't disconnect the battery and now I have ZERO power to anything and can't start my ride. Trying to figure out what burnt out/fried to get her running again. Welcome any advice, starting points on this one to get her running again.
You HAVE to pull the harness, unwrap, and do a full inspection. Anything less is russian roulette.
Did you catch the smoke in a jar or at least a ziploc so you can put it back in when you find where it came from?
Sorry. Had to.
Have a replacement harness for me Mark? My FJ40 is a 72
Sorry. Had to.
Did you recently purchase the new updated and revised version / superseded part # 83100-60180 ?
You can tell if it’s the newer 2nd generation if it has the “ SILVER “
Color Speedo-Cable click on tube / stalk on the back Side attachment point I speak of in detail here ?
Photos would help here , I can make a positive ID for you …
If the newer version superseded KPH cluster meter
I’ll be happy to explain further why this happen to you and what you can do about it also
Thanks matt
Thanks matt
THX @ToyotaMatt I was installing an OEM period correct Gauge cluster, not an updated newer one.
Mine is an early 72, so a harness from a 71 Mark?
Maybe.🤷🏻‍♂️
Best bet is to leave me a voicemail at my shop. I don’t have my inventory memorized, and I won’t remember by Monday without a voicemail.
Thanks.
Maybe.🤷🏻‍♂️
Thanks.
Will call your shop Monday Mark. Thx
