I've used too many electric switching valves for too many years to agree with Steve's comments above. Cripes, every motor home built since the ice age uses them. Perhaps during my retirement years the electric valve companies have switch their supplier to shoddy mfg. companies ???
Thank you so much, I will work on it when I get the part. You guys are the best.
Solace in Vegas, if both tanks had the 120/17 ohm senders, and you used a double pull-double throw switch you should not have had a problem with the senders/gauge readings ???
