My factory front door speakers sounded like crap. The paper cone speakers had worn down to nothing.
Toyota dealership wants 63.00 each for the factory speakers. (No Thanks Toyota)
I took a speaker out of the door and took it with me to several car audio shops in Dallas/Fort Worth area. Most reps (read this as 18 year old with a holiday job) said they'd NEVER seen a speaker like this (Thanks again Toyota). Most also said they didn't have a speaker that would work in the LC. "There's not enough space in that door. Can't be done with an aftermarket speaker."
Some also told me the LC uses a 6 1/2 inch speaker. I guess you could shoe horn one in but not worth the effort if you ask me.
Crutchfield was also not much help in this matter.
So after much research on this forum I found people recommending the Eclipse 5 1/4. However, don't waste your time looking for these, they were discountinued.
What I did find is the Kenwood KFC-1379ie. It's a 5 1/4 inch 2 way speaker. Cost $70 at Best Buy. Also bought some 1/2 inch plastic/nylon spacers in the hardware section at Lowe's Home Center. Only $1 for 4 spacers per door. You'll need 8 spacers. Also bought some 1 1/2 inch screws. Again, you'll need 8 screws.
(You could use speaker spacers if you can find them, however they usually cost 10 to 15 dollars.)
Used the factory screw holes and factory wiring in the door to mount the speaker. The grey wire is negative, the wire with the blue stripe is the positive.
The install took me 15 minutes each door.
I did not disconnect the speakers in the dash and i'm using the factory head unit.
Highly recommend this upgrade. It's reasonably cheap and easy.
New speakers in the doors sound great! (Not audiophile great, but far better than factory speakers.)
Henry
Henry
