Spark Plug ???
Discussion in '40- & 55-Series Tech' started by southerncruiser62, Mar 16, 2004.
  1. southerncruiser62
    southerncruiser62
    3,547
    Albums:
    1
    389
    Jan 16, 2003
    Charleston
    I have heard alot of different things, but was wondering if anyone knew the best spark plug to run in the 2f engine, alot have said to run NGK, but others say champion plugs run better, going to be replacing them, and was wondering what others thought?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,305
    Media:
    17
    Albums:
    1
    619
    Oct 1, 2003
    MN
    ND plugs are OEM, I have had the best luck with them, and prefer them.
    (If they made them for my John Deere 'B', I would have them in there, instead of chumpions)
    Good luck!
    -Steve
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,706
    1,754
    Sep 14, 2003
    Centennial, Colorado
    Use the OEM Plugs! The PO used Bosch and the were to hot.
  4. Chef BoyarDEE
    Chef BoyarDEE
    144
    Jan 22, 2004
    B.C., Canada
    i have ngk's (g-power i think) and have no complaints. all i know is don't get splitfire's, i've nothing but bad things.
  5. southerncruiser62
    southerncruiser62
    3,547
    Albums:
    1
    389
    Jan 16, 2003
    Charleston
    heading to the dealership today to pick up a set of OEM plugs for both the 40 and the 62, thanks for all the input.
  6. Romer
    10,706
    1,754
    Sep 14, 2003
    You can also get them on line for less than $2/ea.
  7. lowtideride
    lowtideride
    7,607
    Media:
    12
    Albums:
    1
    80
    Sep 29, 2003
    The Sunshine State
    i used ngk in the past with no problems...but napa dint have them this time so i had to get bosch..anyone know how much worse they are for your engine??? run too hot??
  8. 60wag
    60wag SILVER Star
    1,926
    40
    Jun 25, 2003
    Boulder, CO
    How can you tell if the plugs are too hot, or not hot enough? Would they have any affect on random pinging?
  9. lowtideride
    lowtideride
    7,607
    Media:
    12
    Albums:
    1
    80
    Sep 29, 2003
    The Sunshine State
    see 60wag is just as lost as me :)
  10. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    ND is my plug of choice, but NGK are also recomended for cruisers in the FSM.
  11. 72cruiser
    72cruiser
    2,709
    Dec 29, 2002
    nashville, tn
    bosch makes real quality stuff, that's all i know.
    just remember to gap em.
    malphrus
  12. Lizrd
    Lizrd
    38
    Oct 13, 2003
    Bosch plugs are trouble in Asian (not Aisin) motors... that's always been my experience. So much trouble that I won't use them in anything. Well, unless i happen onto a bimmer!
  13. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    I agree with that, years ago I replaced the cap, rotor, plugs and wires with Bosch on a 22re.......it ran like crap, swtiched back to OEM and it ran great.
    [quote author=Lizrd link=board=1;threadid=13263;start=msg122681#msg122681 date=1079541807]
    [/quote]
  14. jwest
    jwest
    688
    1
    Mar 12, 2004
    Yea, I also agree about using OEM ignition parts. As for plugs, I use NGK BPR4EY v-power. The '4' indicates indicates a pretty hot plug, though, I believe to keep them cleaner due to the loose tolerances of the 2F. Same with the ND W14EXR-U. Makes you wonder how important it is to keep a cooling system in optimal condition in order to run such a hot plug. Any weakness in a 2F's cooling, quickly shoots the temps up. This brings up another topic ...running cooler plugs (higher number) for hotter running conditions or for overgapped plugs with aftermarket ignitions.
  15. southerncruiser62
    southerncruiser62
    3,547
    Albums:
    1
    389
    Jan 16, 2003
    Charleston
    Picked up the plugs at a local Toyota Dealership for right at $2 (they offer a discount to landcruiser owners, gotta love that), which made me go ahead and pick up a cap and rotor. But i am going to be installing all that tomorrow and will post a reply on what difference i noticed, thanks again for the help.
  16. lowtideride
    lowtideride
    7,607
    Media:
    12
    Albums:
    1
    80
    Sep 29, 2003
    The Sunshine State
    looks like ill be takin the plugs back and getinn another set of ngk's
  17. southerncruiser62
    southerncruiser62
    3,547
    Albums:
    1
    389
    Jan 16, 2003
    Charleston
    Would like to add, just finished installing new OEM ND plugs, rotor and cap and would like to say that, the ole' cruiser is running better than ever, the previous owner had installed NGK plugs but the ND plugs seem to make the 2F run alot better, looks like the 62 is gonna be getting some more plugs next week.
  18. Kief
    Kief
    5,207
    124
    Apr 24, 2003
    Southwest Oregon
    The temperature of a plug is greatly affected by the length of the cone that the electrode is in. The longer the cone the more heat that can build up as it the heat is dissipated through the insulator and to the block, the shorter it is the quicker the heat is dissipated thus a cooler running plug. A hot running plug may cause pre-ignition/pinging. (At least this is what I have been told)
    Anyone ever index their plugs on a 2f?
  19. offcamber40
    offcamber40
    279
    1
    Apr 26, 2003
    Mountains of WV
    Jwest, I run the exact same plug and heat range as you do.. I am being lazy and am trying to overcome a weber carb that is still running rich after a bunch of re-jettings since I moved to 7500 feet.. I also run them slightly overgapped w/ a petronix igbition module and a hot coil.. I like the hotter plugs.. they dont seem to foul as quickly on my 1 mile commute to work (it never warms up!).
    Mike
  20. lowtideride
    lowtideride
    7,607
    Media:
    12
    Albums:
    1
    80
    Sep 29, 2003
    The Sunshine State
    offcamber40,
    RAGE AGIANST THE MACHINE
