Spare Tire Question (2 Viewers)
New Mexico
If needed, could you run a shorter spare tire than the ones on vehicle?
32” tires on vehicle and 29” spare.
Would you run the spare in a emergence?
If so how many miles could you run it?
It will be fine if you have open diff's to use temporally. It could mess up lockers.
I suppose you could always just put it on the front and unlock the hub. You'd have to do half of a "tire rotation" excersize if you had a flat in the back. Front >> back, Spare>>front.
Or, better yet, look on Craigslist for a used tire the size you need. Around here, people are always posting used tires that they've taken off with 30-40% tread. That would be great for a spare. I picked up a spare 33x12.50 Avon (off brand) mud terrain for a spare tire that was brand new from craigslist for $30. Its a much better option than running a tire 3" smaller.
Good luck! :cheers:
Out of curiousity, what is your situation that you have to run a spare of a different diameter? Do you not have the right tire, or is there a space issue?
In two wheel drive, with diffs unlocked it should not be a problem.
If you have an autolocker you will have to put the smaller wheel in the front and unlock the hubs.
If you engage 4 wheel drive, have any type of locker or LSD you will damage parts (diff, gearbox,...)
So it can be done, but you have to know what you're doing.
Personally I have 34" for off road and a set 31" all-terrain for daily usage. With the 34s I use a 31" as spare tire. I know I will have to limp home if I have a flat tire.
Bart
I've used a 31" as a spare when I blew my 33" spare. Only drove 4 miles but no adverse effects. I changed out the diff oil to be sure and no metal or other problems.
A tough trail could get a lot tougher with a smaller tire on your rig.
For street it wouldn't be a big deal with open differentials.
Look on craigslist for the correct size, to play it safe. If you want to use a smaller tire cuz you have it, sell it on craigslist and get what you need.
Similar question..
I have Toyo 33x12.5x15 tires with no spare.
I'm trying to figure out spare tire carrier solutions, but in the meantime, considering just throwing a spare in the back. Can I use ANY 33" tire?
Like a narrower one? How narrow can I go? (not like a bike tire, or those toy car spares)
I'm wondering if it's even worth it just to save just a few inches in width, and also weight. How much lighter is a 10.5 vs 12.5 etc... ? Any ideas? Thanks...
Here's my current set-up:
Secure it!
Similar question..
You could run a narrower tire to save space. I don't think you'd save much weight. 7.50 r16 tires are narrow and similar in diameter. They came stock on some land cruisers. They're a little spooky to drive on though.:steer:
I would think diameter is important, not width. you want the diffs spinning as close as possible.
Option #2;
Get a plug kit and a $50 compressor.
Leave the spare at home.
you know.. I was actually think that too.
Anyone have any real-world experience with that green Goo stuff they sell that is supposed to seal and inflate your tire?
The guys at the tire shop hate you when you use fix a flat, some even charge extra. I need to get a full size spare aswell, I have always liked a rig with a matching set of rims and tires including the spare but five is so much more dough than four. Craigslist is a good source for tires for sure. -Matt
