- Thread starter
- #121
IT TOTALLY DOES. YOU SHUT UP.
I don't think ARB has the concern for the planet to make a product like thatAre those ARB wheel skirts? I can't quite make out the logo.
someone on here can do the math on this but it isn't going to work.
Don't go starting a big argument here!IT TOTALLY DOES. YOU SHUT UP.
In about 20 years, Oregon will have caught up to us.
[/QUO
I know so again I may move again and by then I will be 76 and will not care , you must be voting in them types since you seem so proud of Oregon catching up
OK, so this is starting to become a viable alternative. One big advantage of the seat cushion idea is that it sort of naturally "pumps" the gas back into the tank, eliminating the need for a siphoning system. It also works at all angles. In order for the seat not to collapse, though, you may have to pressurize the gas tank, but I think most 80s already do that
Like this
Once the fuel level in the tubing reaches the level of the tank the majority of the pressure will be equalized. At that point you are relying on the pressure created by the 1/4 gallon of fuel in the filler neck to supply enough pressure via gravity to fill these bags. Not to mention that this pressure must overcome the force needed to open the bags. someone on here can do the math on this but it isn't going to work.
Exactly. thank you for your insightful and additive posts. What about just using bleed air from the exhaust?Good tech.
Issue with this plan is constant change in seat height dynamics. You can already see the test driver in this drawing would have trouble reaching the pedals until the seat fuel bladder is near empty. A taller driver would be fine when the bladder is full and have horrible ergonomics as the bladder empties.
I would recommend a second compensating bladder run from a compressor that would inflate/deflate inverse of the fuel bladder. This would create a constant for the driver rather than an ever changing seating configuration.
A-W-E-S-O-M-EOK, so this is starting to become a viable alternative. One big advantage of the seat cushion idea is that it sort of naturally "pumps" the gas back into the tank, eliminating the need for a siphoning system. It also works at all angles. In order for the seat not to collapse, though, you may have to pressurize the gas tank, but I think most 80s already do that
Like this
Well, as I said, most 80s already tend to build up pressure in the gas tank anyway so it should probably be fine. I think the hydropnuematic seat cushion would be like the 100-series "AHC" for the driver. Pretty awesome, actually.As an environmentally concerned human, I like the idea of reusing something that is otherwise wasted. My only real concern would be odor from the exhaust in the passenger compartment.
Like this
Seven pages of fresh ideas in two days. Unbridled efficiency.^ Yeah, make it a sticky in the 200 section. I think those folk need to see what 'real' tech is...
cheers,
george.
Your new signature is freshCan we make this a Sticky?
