I've had my resettable circuit breaker for the blower motor crap out on me a few times lately, usually at not so good times. It only seems to happen when I am running the AC or heat on full fan blast. Is there a common fix for this or problem area to look at?
Could be that the circuit breaker is going bad and is tripping too easy.
Could be that there is dirt in or around the fan motor.
Could be corosion in the fan motor.
When this happened to me, I replaced the breaker and it still happened.
So I took the fan motor out, cleaned out the leaves and dirt, lightly sanded the comutator (400-800 grit) and cleaned out the groves in between the copper strips, added a drop of oil to each end and it has been working great for 10 years.
The circuit breaker is not like a switch, the more times it's tripped, the weaker it gets. You need to begin by replacing the breaker, then continue with cleaning as mentioned.
maybe I will replace it with a self resetting breaker, then clean out the fan motor for fun. Thanks for the info though, I had never heard of a circuit breaker getting weaker.
