Hi guys and gals, after searching the forum I am still confused. I have a 7/71 with a Delco distributer from Manafre....back in the day 20+ years ago. I'm not getting any spark from my coil. I live out of the country and so haven't been with the truck until a couple days ago. When I left two years ago, the truck was running well and I was driving it around. It has been sitting in an unheated barn in Massachusetts since then with the battery unhooked and has not been started or used. I got back to town and as I said, no spark. Let me add that I did swap out the instrument cluster right before leaving and I cannot be sure if I started the car after doing that swap. Could this be a source of the problem...bad connections or wrong ammeter or...?
So with the ignition on and points open I have juice to the + side of coil and to the minus side though I don't know how much juice. I have juice to the moving part of the points. I've cleaned the connections on the fuse block, on the coil, the rotor and the dizzy cap. I checked for cracks but cap looks fine. Tried a different coil wire and also a different coil but still no spark. Bought a new condenser but that changed nothing. I don't have a voltage meter to test how much juice is running through everything...is that super important? I'm trying to avoid spending the cash for one. (...don't have a lot of that right now, cash that is).
Some other info: the ignition cylinder is a bit wonky and putting the key in the "on" position doesn't always turn on the juice and it must be jiggled. But I circumvent this by pulling the connector off the back of the key cylinder and completing the circuit with some wires so I would think this would eliminate this issue from the spark issue.
I have run a jumper from the + battery to the + coil and tried to start but no change.
I am confused about this:
"Pull center wire from distributor and place it 1/4 inch from the engine block.
Remove the distributor wire from the - side of the coil.
Turn the key on.
Momentarily ground the - side of the coil and check for spark. If it sparks, reconnect the distributor wire and manually open and close the points and see if it sparks.
If it doesn't spark, then run a wire from the + battery post to the + side of the coil and try again.
If it sparks, then the ignition circuit from the key switch is bad."
In the above info, "turn the key on" means crank the engine?
Thanks all. A bit long, I know, and an all-too-common topic.
Cheers, Sproggy
Turn the key on.
Cheers, Sproggy
