I’m down to my final issue before I can actually drive this thing (in 2wd anyway) and could use some help on the final trouble shooting. Thanks for being with all of my questions, everyone here has been just super supportive.
The basics: ‘68 SBC with Th350 / Np203 and Toyota T/C rig now running dual line Lexus dual line M/C and mid 80’s power booster. FJ60 front brakes and JT Outfitters rear disc set up. Lines are all new 10mm inverted flare. Wilwood rear brake proportioner adjusted for no reduction in rear stopping power. System is leak free, have bleed it but not 100% sure I got all the air out.
My brake pedal is out of the car so I’m pushing on the brake clevis with my hand but I can fully depress it with the engine running. It is very hard to push on the clevis with the engine off.
Issue: with rear of the rig secured on multiple jack stands I can start the rig and shift through all the gears. Brakes will stop the rear wheels in reverse and from spinning when I shift into neutral. When in drive they will momentarily stop the tires from spinning but the wheels will start spinning again even with the brake pedal continually depressed.
Does that sound like air in the system still or more like a booster pushrod adjustment issue? Other ideas?
Thanks again - this build has been all new to me between the Toyota and SBC drive train.
