all right, so it's been amply made clear that we all gotta put on the biggest tires that will possibly fit without rubbing, and then some... otherwise we are no real men and barely qualify as pansies
and, yes, I imagine if you get big ones you may need to regear if you want to go uphill at a reasonable clip (let's not even mention the 91s and 92s when one talks about uphill and reasonable clip in the same sentence, eh... ).
But what's not so clear to me is what the result of the process is likely to be. IOW, what do big tires do to the rig? I imagine heavier tires would likely increase the stress on the suspension, bearings, birfs (oh, the horror...!) etc. Is this likely to result in accelerated wear and possibly damage, even with only street driving?
Any serious info out there on what damage if any would result from the use of bigger tires (say 35") if one were to limit oneself to light off-roading (read no Moab stuff)? Any parts particularly likely to fail?
thoughts?
thanks
Eric
thoughts?
thanks
Eric
