Something other than 62 rear shoulder belts for a 60?
Omaha, Nebraska
I just spent an hour going through search trying to find info. I have spent about 2 months trying to track down a set of FJ62 retracting rear shoulder belts to convert over my FJ60. I have posted here in the wanted section several times, and have been PMing with some members, but to no avail.
My question: has anyone used rear shoulder belts out of anything else to do this conversion? There are a couple of good import salvage yards here and I was thinking of looking at 4Runner or Camry rear belts. Anyone have any experience with something other than FJ62 belts?
I need to get this done soon, my 4yo is just about to outgrow her old seat.
Thanks, Hodag
Are the FJ62 ones retractable?
Are they like newer models where they will ratchet and lock if you pull the belt all the way out?
I seem to remember that they were manually adjustable, like SOR sells in the link above.
Several people have said they did not like this set up- they could never seem to get them tight enough.
I still have the set Orangefj45 and I told you I had. I just have not had a chance to take them out yet.
Now I know that your 4 year needs them and not you just for trail spares or the "cool factor", I will get them out this weekend.
Thanks, I sent you a PM just after I posted this. I'll be waiting to hear from you.
Hodag
I've got retractable in my '88 62, but dissapointingly, they're just retracting LAP belts, no shoulder. I'm OK with this, but of course, I'd prefer shoulder belts too. I did check and the holes are threaded, so I'm good to go, if I also can find a set. When did they make the upgrade? '89?
Seems to be they switched over late in the run of 88 models. I don't know of an 89 with laps only.
Your 88 is probably set up just like the FJ60's- no rear headrests, either, right?
I'm like others and don't think my pillar has a threaded hole, so...it's about time to get creative like others have done.
Bump for the picture of the aftermarket belt install.:bounce:
I'll double check, but I think it has rear head rests. If not, I have a back-up rear seat back from another 62 that does have the head rest holes (but no head rests), which I can swap in. But, I'm faily sure I double checked those pilar holes and I'm prepared to bet that they're threaded. There are also threaded holes for the rear grab bar that is diagonal and just behind driver and front passenger's heads, as well as passenger grab bar on the A pilar. You gotta put in as many grab bars in as you can get your hands on...
Edit: according to the photos I posted in my own build thread, I'll be needing that other seat back...
Great, it's brown (Tofu is gray), I'm headed back to Partridge Family mismatched interiors again!
Looks like might have to change bolts
I like those harnesses, and thought about using them as well. I have seen some similar ones from other aftermarket seat belt web sites. Where will you mount the top portion? I assumed it needed to be straight up and over the back, not off to the side.
I have a set with the plastic trim pieces for $90 plus shipping. Sorry it took so long to dig them out. Been super busy at work. Let me know.
Well, I've read that you are supposed to mount them straight back in which case you would need to install a bar between the C pillars to attach them to. The main reason I guess is because you don't want the belts compressing your spine in case of a roll over.
However, since my kids' shoulders don't go above the top of the bench seat I am going to mount it to the floor behind the seat. Other people have done it this way as well. I eventually want to replace the rear bench seat with suspension seats or a suspension bench seat. As my kids get older, I'll reevaluate the situation.
