I just finished up about a week working on the 100.
Timing belt, water pump, pulleys, hoses, starter contacts and plunger, cleaned intake plenum, valve cover gaskets, PCV valve, fuel filter.
My valve cover gaskets had been leaking, so I replaced them while doing all this other stuff. Had a bolt break off on the rear of the head, that was a hole lot of fun to get out. Finally drilled it out and put a helicoil in.
So last night I go to start it up, and had a few lights on the dash: battery, check engine, and a/t oil temp. It still started up just fine. After about 5 seconds I started to notice a small amount of smoke coming from the rear of the DS exhaust/valve cover area. I thought the valve gasket may have gotten pinched, so today I removed the valve cover, only to find it in perfect condition. So, cleaned up and reinstalled.
Then I thought it may be all of the penetrating oil I sprayed on the bolt to get it to brake free which also coated the heck out of the exhaust. So I rolled the truck out, sprayed some degreaser along the headers (while cold), let it sit and then sprayed the area with the hose on low pressure. Then I used the air nossle to blow away any remaining water, started it up again. After about 15 seconds, some smoke started again from the same area.
I've tried reading (via scangauge) to see what the dash lights mean, it says there are no codes at all.
Any thoughts?!?
Any thoughts?!?
