This is a weird one. After replacing my injectors with new Toyota injectors and putting in a rebuilt IP the Cruiser has been driving really well. Great power, great fuel economy (20mpg if I keep it around 2400 rpm). It drives better than it ever has.
Then the other day, I put it in park and revved the engine after tuning the pump to see if it produced any smoke. When I did that, the RPMs rose up and would have continued if I hadn't shut the truck off. This was in park. Next morning, I did the same thing once I started it up and it didn't do it. Only when the truck is warmed up.
I did a visual inspection and it doesn't look like the throttle cable is sticking or binding. The hand throttle knob isn't pulling either.
The turbo was rebuilt two years ago with all OEM parts and re-installed by Mudrak, so I doubt it’s the turbo seals. No leaks anywhere. 180,000 miles on the clock. New fuel filter and I just changed the oil. Compression numbers are 430 across all 6 glow plugs. A442F hydro transmission with new fluid that shifts clean. Kickdown cable is adjusted perfectly.
It's never done this to me while driving but I'm worried it could happen. We're supposed to take the truck on the road on Monday and would feel better if I knew what could be causing it.
