- Location
- United States
Looking for a good pair of mini truck, solid axle Aisin hubs (1979-1985)...OE Aisin hubs only please!
If they are the same ones Roger is selling, I read some scuttle on the forum last week about QC.cruiser outfitters sells new ones, for a reasonable price.
If they the same ones Roger is selling, I read some scuttle on the forum last week about QC.
How are the 79-85 mini truck lock out hub different than the later FJ40?
Yep - That is the cheapest option, considering used Aisin IFS hubs are still relatively plentiful at junkyards for $50/hub. Finding good 30-spline inner gears to swap into them can be an issue though. Trail Gear sells some Longfield chromoly inner gears but they’re a little pricey ($135). However, buying two used IFS hubs for $50 a piece from a junkyard and swapping in the $135 Longfield gears would still be cheaper than buying new Aisin SA hubs ($320 for a pair).the hub bodies and lock out are the same on IFS trucks, just the inner gear needs to be changed to fit the birf versus the CV axle
I've used good IFS parts and swapped the gear and they worked the same
You can get the RCV inners for $110. I don't know if RCV still make the Longfield ones since Longfield was bought by Trail Gear, but a bit cheaper and I expect as good or better quality.Yep - That is the cheapest option, considering used Aisin IFS hubs are still relatively plentiful at junkyards for $50/hub. Finding good 30-spline inner gears to swap into them can be an issue though. Trail Gear sells some Longfield chromoly inner gears but they’re a little pricey ($135). However, buying two used IFS hubs for $50 a piece from a junkyard and swapping in the $135 Longfield gears would still be cheaper than buying new Aisin SA hubs ($320 for a pair).
I would check car-part.com to see if there are any used SA or IFS hubs near you and then go from there. Might get lucky and find some SA hubs at a junkyard close by.
bummer that is not good. I don't know what ones Kurt is selling
maybe Kurt will chime in
@cruiseroutfit
