- Location
- United States
1999 Toyota Land Cruiser 100 Series, Imperial Jade Mica, 178k miles. Rear locker.
Acquired in 03/2018 with 174,680 miles on the clock. Since then, the following maintenance has been done (paperwork available):
UPGRADES
1. Door lock actuators front passenger side and rear driver side "sticky" when it gets very hot but otherwise work fine. Can be fixed by changing actuator motors.
2. Issue with rear bolt holes on frame. Documented here
3. Some dings and dents but the truck shows very well - judge for yourself by the pictures.
4. Clear coat is failing in some areas (faded top right quarter panel near the roof - not too visible) and around the window moldings
Other than that, it drives like a dream. Transmission shifts like butter. Cabin is clean and quiet. Very minor undercarriage surface rust - this was a CA and Southern vehicle.
Reason for selling: I bought this truck planning for a South American trip but plans have somewhat changed. I may upgrade to a 200 in the future.
PRICE: $13,700
Thank you for looking! PM or comment if you have any questions.
- Heater Ts replaced
- Steering rack replaced
- Differential fluid changed (rear and front)
- Cooling system flush
- Lower control arms replaced
- Right CV axle replaced
- Valve cover gaskets replaced
- Spark plugs replaced (8 x Denso Iridium)
- Last oil and filter change at 177,645 miles
- Timing belt done at 139,587 miles
- Brake master cylinder replaced at 139,587 miles
UPGRADES
- Tough Dog Suspension 53 mm front and 45 mm adjustable rear shocks / Dual rate coils (0-660#) / Torsion Bars
- Trail Tailor diff drop kit
- SPC Upper Control Arms
- Gamiviti Expo++ Roof Rack
- Metaltech Sliders
- KISS drawers
- 2006-07 OEM headlights with HID conversion (by Lightwerkz)
- 2007-07 style aftermarket LED taillights
- Sony XAV-AX100 Head unit with Backup camera
- Focal Performance PS 165F front speakers
- SCS F5 Wheels (5)
- BFG A/T KO2 285/75R16 installed at 174,841 miles
- Dynamat Sound Deadening installed on floor
- JDM OEM 200 Horn
- JDM OEM Rear wiper
PRICE: $13,700
