thecrazygreek
A.K.A. TheCraftyGreek
- Location
- United States
I have a set of LED headlights that were purchased through ICON.
Here is there write-up on these lights...
They sell these for $285.00 each! I'm selling at $300.00 for the pair. (shipped) They are like new...
FJ Headlights
The signature ICON FJ Series Headlights are powered 100% by Light Emitting Diodes (LED's). Sold as single units.
When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance.
Excellent option for light, medium and heavy-duty trucks, off-road vehicles, classic cars, motorcycles and more.
Metalized reflector optics provide a lighting experience that smooth and clean across the driving surface.
Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility.
Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration.
Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards.
Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture.
Advanced circuitry protects against voltage spikes up to 600v.
Drop-in replacement for #6014, 6015, 6016, H6024 and Par 56 headlamp designs.
Uses standard, H4, 3-blade wiring connector.
Equipped with Truck-Lite 3-Year Limited Warranty.
US Made!
16 Gauge Wire
Light Source:
2 LED Arrays
9v-33v Multi-volt design works with both 12v and 24v systems
12.8v, 1.80a (low beam), 3.60 amps (high beam)
25.6v, 1.00a (low beam), 1.80 amps (high beam)
1,300 Lumens!!!
FJ Headlights
US Made!
16 Gauge Wire
Light Source:
2 LED Arrays
1,300 Lumens!!!
