soda blast
Never heard that one. Perhaps I'm about to learn something?
You know that soda will not remove rust, right? You'd have to switch to coal slag, alum oxide, etc for rust.
local powdercoater here uses plastic media as to not warp the body.
anyone that soda blasts can use a formula that has an abrasive in it that will remove rust. Of coarse you would have to take measures to protect glass etc.
Really only looking for info on paint adhesion to soda blasted metal. I have new heritage rear quarters rockers and floors, so rust is gone just looking to clean all the paint off the body without sandblasting it.
I knew about that but never seen it done. What kind of a profile does it leave?
From what I could tell, a very smooth profile. No pitting anywhere. Definately no chance of body panel warping. The media is about the size of a match head. Tho not sure about removing pitted rust, etc.
Fair enough, didn't mean to derail ya. I took your 'rust never sleeps' and ran with it.
Try www.eastwood.com or www.autobodystore.com and poke around their forums for a possible answer. If ya find anything, perhaps post it up here?
Yea rust never sleeps! We just slow it down some. Thanks for the links asked the soda blasting question there also so we'll see. My paint supplier told me about this problem but if you prep the surface after blasting I can't see why there would be a problem.
If this is a valid concern, I wonder if it's a pH thing, or a lack of surface 'bite' thing? If it's either, they both are easy fixes.
I have posted this question on [www.autobodystore.com] and had 2 replys, one reply was to make sure to sand the entire metal surface after blasting, and one that had paint problems? no other details although madia blasting was recomended. I may go that route.
Here's what google turned up this morning:
This is a cut and paste from a Nova forum.
"Well I contacted Sherwin Williams Automotive paint and this is what Rose Gasper, Customer Service Rep, had to say. "Application of a primer with minimal acid congertration such as etching fillers, vinyl wash, or metal preps, will react with sobium bicarbonare. This will emit carbon dioxide potentially causing blistering of the paint and then total delamination of the paint and undercoats".
Then Rose Gasper wrote the following steps must be adhered to. Observe recommendations specified by the company that produces the soda and the maufacturer of the equipment used. Then before applying any refinish materials, thoroughly clean the surface with soap and water, preferably with a pressure washer, then dry. The third step is to inspect the surface for any white residue. If a residue is found repeat the second step. The last thing is after the surface is thoroughly clean, and no residue is found, follow manufactures specific recommendations for bare substrates.
I hope this answers any questions you may have."
The preceeding post in the same thread stated:
"Warm water and vinegar will remove the residue. I add in a red scotchbrite and have had great results with small parts. I havn't done a full car yet. I also don't know any paint company that is going to warranty a paint job. When I was painting full time we had a problem with a color and called the jobber, they did replace the paint but wouldn't cover our time wasted."
Sounds iffy, I dont really want to spend a lot of time and cash and have my paint peel or blister, sounds like you could be real careful and still have problems.
Although I talked to a guy at Aqua Blast today and he said that he blasts with Arm and Hammer blasting soda he says it has a a chemical in it that leaves the soda neutral? after he is done blasting he power washes the metal drys it sprays it with metal etch then washes it with soap and water. Lot of steps to get the powder off.
I have used soda blasting in some of my builds. The only thing you have to tell the person or shop doing the paint work is that it has to be completly free of dust etc. Then it has to be wiped down thouroghly with vinegar. If you try to wipe it with a cleaning solvent all it will do is smear. Vinegar first then prep solvent. It will stick and it leaves a baby butt smooth surface. It will not remove rust though. You will need to take care of that before or after soda blast.
Here is a link www.sodablasting.com
Call them talk to Bill or Brian these are great guys to deal with and they will give you the straight from the horses mouth answer.
sounds like alot of rigamoro.
I guess if you get something sodablasted, I can't imagine or can understand MORE steps for painting prep. Vinegar, etc. I would opt for a different media with less bs involved, IMHO.:cheers:
I was considering soda blasting for cleaning the 40 body but I hear about paint not sticking to the metal after. Is there some type of metal prep that has to be used after blasting?
I do sodablasting I do a lot of blasting for the local body shops in my area. I have done vettes merceds old mercs etc. I am not a total expert but I got a pretty good resume. In answer to paint not sticking after sodablasting. I know all the jobs I have done you wash the car down warm water and dishwashing liquid or vinegar and water. It is no big deal. I highly recommend sodablasting over the other types of blasting. 1 you can rinse away soda it will displace 2 It is totally harmless to enviro 3 The finish is excellent. Don't get me wrong sand dose have it's place as dose other types of media's. The jobs I have done where I have encountered rust those areas where gonna get cut out. The areas that had just surface rust the body shops I worked with would use a DA on it and prep the area accordingly. Hope this helps you.
Get it blasted, then wipe or spray it with 3M MetalPrep, wait, hose off and you have a perfect surface for paint.
Ed
Ed
Did some checking with the local sodablaster, and after further review, I concur. Belay my former posts. Good, plain and simple Degnol.
Gee, 'Elk, thanks! As I recall, i have received some great paint advice from you in the past. You're a professional painter, aren't you?
:beer:
Ed
:beer:
Ed
The 3m wipe down was the main ingredient . Another soda blaster said no prepping after(:rolleyes:). I know a lot about paint, but mostly on the industrial side;), which can be applicable in the cruiser nation.
+ I just can't see shooting a cruiser after all that work, to see it fail. That would really suck. I am going with the cleaning aspect, post soda blasting.
Nuff Said.
