- Location
- United States
In the car. You can start it run it, test it and enjoy it. Good oil pressure, no smoke, runs normal temperatures, no mixed fluids, no noises, and runs strong. Price is if you pull it. If I pull it, add $150.
Idles smooth. A sweet engine!
The car has 200,500 miles on it.
$1500 complete with manifolds, sensors and everything, you pull it.
$1250 complete without manifolds, sensors, alternator, AC compressor, PS pump, starter.
Transmission shifts smoothly, no chatter, no slip, no leaks. $300 firm
Transfer Case - does it's job quietly and with no issues $275
Feel free to take a compression check on the engine, analyze the oil, or do whatever inspection you would like.
I will remove the engine and load it into your truck or trailer for $150, or you can pull it and I will still help you load it.
I have an engine hoist here and the car is parked on concrete.
Available most days to show, unless I am out 4 wheeling. Exact interchange with 1995, 1996 and 1997. Will fit right in 1993 and 1994, by using the 93 or 94 intake manifold, air flow meter and OBD1 sensors. I did this and put a later engine in my 94.
