SOA Flexible Brake Lines?
What brake lines do you guys use when you do spring overs on fj40's, I have a 71 that I'm swapping mini truck knuckles on?Thanks
there's a long hose part number in there, and you can use the short hose from the housing-to-knuckle connection to double up if you need to.
You can also buy the Toyota truck extended lines from ProComp etc because all Toyota lines are the same.
