Putting a feeler out here and thinking about selling my 60 series axles under my SOA 55 to fund a solid axle swap on a 100 series. These axles are complete and built ready to go. The perches are the same width as a 55 frame so they should fit a 40. You could also move them out and put them back under a 60 series. Axles will be sold complete ready to bolt in.
Front axle -
ARB RD142 air locker
Nitro 4:88 gears and master install kit
Nitro Chromoly birfield inner and outers.
4x4labs Hi steer arms with one ton tie rod ends
Extended stainless steel brake line to the frame
Complete rebuild with marlin crawler eco seals.
New pads, rotors, and calipers
Cut and turned for 5 degrees of castor
Rear axle -
ARB RD153 air locker
Ruffstuff anti wrap bar - Going to cut the rear cross member out of mine and include everything.
Also included is the ARB CKSA12 air compressor for the lockers. Also all the wiring and switches will go with it.
Truck has not been driven much since I built the axles and did the SOA. I would say it all has around 1,000 miles on it. I would be interested in knocking some off the price for your stock 40/55 axles to put back under mine. Asking $3,750. Located in the Seattle area. Would be willing to ship them on a pallet but that would probably be around $300 if I had to guess.
Front axle -
Rear axle -
