So I thought fixing the broken sway bar link would end my front suspension creak... (1 Viewer)
Sam's Clam Disco, CA
So I've had a squeak/creak in the front suspension for a while, and dug into it today expecting for find a broken sway bar link (which I found). I swapped out the broken sway bar link, and the squeak/creak persists.
It seems most consistent on bumps (speed bumps are a guaranteed replication), however I've heard it when turning as well.
Any thoughts on where to look next? Any lube points in the front suspension I should hit?
DC
Ball joints
Sway bar links would make clunking noises going over bumps, squeaking/creaking like opening a heavy wooden door would most likely be your balljoints drying out of grease.
JunkCrzr89
Competent Ignoramoose
Colorado
Ball joints
Clunking is often control arm bushings, too. But I agree with you that OP’s problem is likely ball joints.
DanInDenver
GOLD Star
Denver, CO
For me the squeak creaking noise was the PS sway bar mount. The one under the air conditioning drain. My bar was rusted there and had poor contact with the mount. Used sway bar and mount bushing installed cured the problem.
