Your engine placement isn't too far forward at all. It's right where it should be. Run it.
I believe I see your problem.... Too many things in that list. Parse it down into vehicle systems. Then, parse that list down into components. Then attack...Very long post very long post ahead....
....Tha'ts just the stuff i remember
Yeah, after looking at his list, that was my though too.Loosechange ... Just my 2 cents but personally if you want to do this properly I'd tear the ENTIRE truck down to the last nut and bolt.
Tag everything in bags and start from ground zero ...
Tag everything in bags and start from ground zero ... in the end the truck will be 1000x better and I believe may take less time in the long run
Been here and done (doing) this ... and you'll regret later not doing it this way, will save a TON of headaches
Cheers
Steve
Get your hot cocoa ready and put up your feet..: and my images I have up are in my media are under loosechange
Base 1972 Toyota FJ40 Toyota Land Cruiser (April 1972) Frame, clip and body matching numbers
try to do 1 thing a week will take way up to multiple years to complete. go through priorities then recall time
(?) means not a priority
clean out rear end and move front end into the living room as well as tranny
1. *** Redo Steering stabilizer mount— install inside of leaf spring area not in between. Refer to picture
2. repair crack on top of fender well by roll cage (?)
3. want to have h4 lights (?)
4. *** home depot to get equips to custom make a ghetto roof rack tire carrier…Done
Using garvin industries roof rack and floor with a spare tire carrier up top
5. *** NEED to repair existing seat or repair the new front driver seat (?)
6. sell front split and drivers as well as can for emission in the front split….find metal rear panel and reinstall (?)
7. want grab handle over glove box (?)
8. *** Need door limiter straps (passenger door non operative) (?)
9. *** want swing away carrier (?)
10. *** want/ need ’76 bumper and taillights to work this set up for swing away (?)
11. *** Drive shaft mounted for roof rack —done (?)
12. *** Need new front drive shaft due to small twist in shaft !!! get back from desert tools but check if engine is too far forward since drive shaft u-joint area is squished... picture soon maybe tonight
13. *** want speedo to work/ cable seems to work (?) but maybe gear in tranny bad
14. *** want front ford shock towers
15. *** want to mount fender turn signal have rubber grommets to install xenon flashers -done with small hole in fender flasher and bulb now(?)
16. *** 4 speed with an Orion
17. *** want to buy rack and lockdown bar for oils -done , I’m using Ammo cans straps bolted to roof rack
18. *** Install the rear holder for jerry cans/igloo/yeti etc (?)
19. *** need Axle wrap bar from Desert tools _dont need due to having SUA but i really wanted t for looks and fabwork anyway(?)
20. *** need to fix leaking fuel line at pump-done
21. *** find a new place to mount fuel pump and filter-done (40Micron)
22. *** Need wire for glove box (?)
23. *** original Front wing windows need newer gasket around them (?)
24. *** Need swing away carrier already stated above (?)
25. *** need to redo exhaust with new collector bolts and gaskets-done
26. *** need to hook up electrical to washer bottle-done,
27. *** need to loom wiring-somewhat done but still ghetto
28. *** re-mount fire ext. even if on
Ehis empty- bought new (3 of them) but saving 200.00 more bucks for a COLD FIRE system
29. *** Doors need new gasket around edge. (?)
30. *** Install Switch box- rebuilt with Marine switch box relay breakers and blue sea fuse block
31. *** fabricate Switch box holder
32. *** Need Rear 2lbs residual valve..-maybe i don’t know yet
33. *** want pass door to moderately work if possible, the Passenger does not mate. Re-drill hinge holes to work I guess (?)
34. *** want a good torque bar to rear end by ‘desert tools of az’ REFER to axle wrap earlier in post (?)
35. *** want front pig cover protection bash plate maybe even (?)
36. *** want pinion protection (?)
37. *** Need 6 gallon blue water jerry can
38. *** Trans adapt oil filter relocation kit not installed yet
39. *** Derale Duel row oil cooler with fan -Done
40. *** Hitorque 4.2 HP small starter, installed but dopnt know if it works yet cranking engine or needs shimmed
41. *** 16 gauge cut heat shield for starter butdon’t know if shimmed properly
42. *** PPI External starter solenoid (not in use)
43. *** weld shock mounts onto Conn-Ferr leaf spring skid plates-not needed , Shock mounts are now above leaf spring on rear end
44. *** mount conn-ferr skids to rear leafs once shock mounts are welded on- shock mounts not needed on skids
45. *** mount large compressor beind rear jumps on- have the 20007 system but no where yet to install
46. *** need HD rear pig cover gasket
47. *** need the bolt for fill plug rear cover-done
48. *** need rear pig fluid for locker-done
49. *** re-do exhaust so cross under is closer to leaf spring hanger
50. *** purchase another ear for front bumper mount CB ant.
51. *** Skids and Plates tranny and engine oil pan (?)
52. *** sliders online will I need to change exhaust??? (?)
53. *** mount my belleview/warn winch and roller fairlead. sandwich the plate for fairlead between bumber ….refer to hand drawn pic
54. *** hang 2.5g air tank under vehicle in front of fuel tank area and up high
55. *** re-install temp gauge and volt meter-done
56. *** adjust carb from loading up at idle…use vacuum gauge for reading at idle and adjustments at idle
57. *** remove tank skid to reinstall pintle
58. *** install rest of SOR roll cage…keep dash pad even if I have to use a heated wire to cut the foam out
59. *** fix leak at pump when Im changing the hose-done
60. *** need compression ring for front arb line ( cut line and take piece to four wheelers)
61. *** buy Logic probe 3
62. *** try to find 4.7 caddy air cleaner and MAKE it work for my air cleaner… i don’t want just a k&n pre cleaner installed
63. *** find a place to mount oil cooler with 650 com fan…not under seat. I could mount it on roof rack hide the aircraft line (#8 hoses hidden in large electrical tubing) ?
64. *** Do i want to re-mount the tank under front seat and have to go through the process of fabing a tube for gas.
65. *** if I mount tank make sure to use the manual fuel tank switching switch (refer to image)
66. *** find a place to mount the relocated oil filter transept -done
67. *** mount RCI puke can
68. *** install some sort of lights to see under hood
69. *** fix exhaust leak, need vehicle running first which means I need to hook up battery and test the starter is shimmed right to flywheel
70. *** time engine better. Why is the MARK so far off, use white out to make new timing mark.
clean out radiator.
71. *** hook up window washer bottle again and hose??
72. *** purchase 2lbs residual wildwood brakes valve already stated
73. *** re-purchase up to date front disk brake conversation from Man a Fre -the ones on truck are old school and now old 2 piston wilwoods
74. *** light bulb for interior light
75. *** hook up power wire for interior light
76. *** make sure DS wiper motor switch works
77. *** want rock sliders and skids and weld work on front pig
78. *** original Front wing windows need newer gasket around them
79. *** want to Buy “cold fire” system or SAR Aquas system
80. *** Need to reinstall trailer hitch electrical socket
81. *** need extended breather hose for tranny and transfer with small air filter at end
82. *** Might need new Chevy power steering pump
83. *** want another battery-done i now have a yellow top and red top
84. *** need PPI painless wiring mastermind isolator kit-Done but not PPI I got hell roaring technologies 95300B iso
85. *** Install disk brakes onto rear end while in living room
86. *** take pig and locker to 4 Wheelers to install
87. *** put pig back into the rear end
88. *** mount rear end to vehicle after removing 1968 rear end—done
89. *** have rear 68 pig put back together and remount into rear end-Salvaged and stripped
I want skids, protection, rockers, i have no undercarriage protect. d0 I need it with just doing back country an lake stuff through washes and up berms etc.
complete spare front axle assembly with all parts still put together =driveline in back of bed
complete rear assembly for disks and reinstall locker
two extra rear axles for a 72. long and short
heavy duty teflon lined AN brake lines =brakes-done
bungies for front brake line for articulation ( keep them from twisting up) =driveline/brakes
custom made front drive shaft =driveline/trans
I Have another front windshield gasket.
have vacuum actuated transfer I need to sell =driveline/trans..want to mount my manual actuated transfer onto the newer(nos) transmission before they put it in
Autometer mini sport tach =monitoring-done
RPM Fabrication work - Gusseted frame at front =fabwork-done
Steering collar by RPM Fabrications =fabwork-done
Re-Worked shackles by RPM Fabrications =suspension/fabwork-done
have 5 gallon katydyn water bag-done
350 Chevy conversion with shaved heads (245ft/lbs @ 2500rpm-80,000 miles on motor since rebuild) =motor
HEI Distributor =motor
New Toyota window regulators/cranks NOS
Aftermarket ignition switch from AutoZone (have original but needs a key made) =electrical
got rid of the aftermarket and purchased an NOS ignition switch
New wiper Switch NOS. needs hooked up to motor (have 1968 windshield frame not 1972 so it has 2 individual motors…I have a red cap switch operating drivers side motor i have two more wiper motors with wiring but don’t know if they are synced
XRP/Earls #8 aircraft hose and AN fitting for oil filter relocation (not installed yet) =oil/lubes
Partial electrical wiring looming =electrical
10 fuse gang block, ten waterproof switches with breakers, 10 – 30 amp relay =electrical
Dbl Header gaskets by Edelbrock =motor
High heat blanket for starter =motor
Dodge Diesel Battery #2ga insolated cable starter wire =electrical/motor
Block hugger headers corvette style =exhaust/motor
2-40 series dueled flowmaster mufflers=exhaust
120 amp Hitachi one wire alternator internal regulator =motor/electric
removed Hitachi and now running a Powermaster 3/1 wire tested at idle 104 amps, cruise at 145 amps and WOT 165 amp and at 14.6 built 6/5/17
#2ga alternator wire =electrical
Phoenix gold negative battery clamp =electrical
Front wheel two piston wilwood disk brake conversion =brakes
Wilwood 2lbs front brake residual valve =brakes
Front DBA Gold slotted drilled and chamfered rotors =brakes
Rear DBA Gold slotted drilled and chamfered rotors =brakes
Windshield wipers NOS
Man a Fre rear single piston disk brake conversion =brakes
Original dual reservoir brake cylinder =brakes
Baer rear wheel brake adjustable proportioning valve =brakes
blue torch fabrication off road Heavy duty rear diff cover =differential
8.8 metric rear end carrier studs =diferentail
New nos hood hold downs and hood rubber for clip
Have front grill hinge but no way to install.
New nos rear hatch handle Exterior and interior I just bought
Working hatch rods for rear hatch
Working dbl rear swing doors
Rear LED reverse light =electrical/lighting
10 flange wip nuts
Ballistic fabrications Dual Battery box not installed and need =electrical/battery
Yellow top Optima battery =electrical/battery
Redtop Optima for backup starting battery
Extended #6 aircraft line/breather for valve cover-pac
Auto-meter electrical volts and Water temp sending unit
New external electrical switch box with:
“6-waterproof 20amp 1.5 hp toggle switches and waterproof covers, 6-breakers, 10 gang fuse block with common positive and 6-30 amp 4 pin relays, main power in 140 amp phoenix gold breaker” for Fuel pump, MSD main, Msd distributor, Elec rad fan, elec oil cooler fan, purge pump for inner water bilge for fording.
2-75 amp sollniods PPI one for relay to starter one and one for winch. not using for starter.
4400 FlowJet purge pump for use for after fording, use as a pump or siphon water from places for hand washing etc. or to siphon fuel etc
3” snorkel system of main pvc induction for external air cooler to carb (not for water fording per se, but cooler air and or limiter dust etc.
K&N air cleaner
SOR front Roll cage kit (not installed)
Aftermarket rear roll bar kit by Smitty-built
Rear roll bar pad
Three abc fire extinguishers inspected and test 2015
rear clevis
have large camping waterproof quartermaster bag for roof rack
Cats Eyes rear corner lights flood
KC rear middle Spot
two Nite rider 30w for back up spot
Switch for back up light Nite rider lights separate from tranny backup light switch
Hella 300AMP emergency cut off switch
Uniden 78elite CB
5ft Wilson silver load CB antenna
Cb antenna quick disconnect
Incline /Tilt Guage (NOT JDM) sold that one for 150.00 it was for a RHD and i didn’t want to have it shimmed
3 ft secondary firestick CB antenna
Large Autometer Sport comp tach……need to test
Autometer Sport comp mini tachometer
Hi lift, shovel, pro-comp strap, recovery equip.
Hi lift jack mount garvin wilderness
Upper spare tire mount to roof rack
Misc ammo cans for oil, tools, belts, hoses, fitting etc.
RCI puke can (overflow bottle)
Rancho 5000 rear shocks
Rancho 5000 steering stabilizer
Rancho RSX front shocks
Warn locking hubs extra, warn premium locking hubs extra, Selectro hubs being used..these are the ones before mile marker bought them out.
6 red saftety switches for all offroad lights, spots floods and rock, 6 fusable links and relays.: 1 road 5”rear offroad spots, 2 rear off road corner roof rack floods, 2 roof 30w lights rear backups, 2 rock lights, 2 upper roof rack front KCs, 2 bumper floods front but going to be pointed sideway to see what the heck out to the sides when in the washes
Flow Kooler shortneck water pump
185* Flow Kooler thermostat
Edelbrock 1406 Carberator
Edelbrock aluminum manifold
new airquipt manifold heater hose line with removable filter (scale and nasty from anything that been sitting in the core for so long
MSD 6AL
MSD Sparkplug cables 8.5mm
MSD External REV limiter dial
MSD Blaster coil
Ron Davis Radiator
Black Magic Extreme 3300CFM electric fan with built in radiator shroud (mechanical on/off relay switch inside, but controlled by temperature of radiator maradyne switch in manifold
Rebuilt entire front axle end, bearing, wipes, races, etc. all re-done new hubs held on with studs not bolts
Locking hubs with lacing bolts - need lacing wire)
ARB air pump
ARB front Locker
Rear Rebuilt full Detroit locker
Duel rear shock mounts already available... although skids are on I saved original bolt plates with the shock mount studs on them
Viair 400c pump
Firestone 2.5 gallon air tank for tires and or other apps
Viair small pump for airhorns
Haldley 130dB dual air-horn switch pull strap accuated
Viair 1 gallon air tank
Have rear and front limiter straps (not installed, will need rear ears welded to install rear straps)
4 conn-fear Leaf spring skid plates installed)
Extra Conn Ferr extended dog bones for leafs not using yet. Just extras
2-1/2” Dog bone lift
Advanced Handling Systems front end shackle kit (Needs reverse)
Super Duty front bull bar with D RINGS
Bellvue 8000 winch ( bought out by WARN-this is Identical to the 8274 winch)
External breather tubes for Axles and fuel tank
B&M Super cooler for power steering installed
Saginaw steering conversion RPM fab installed
Aircraft type line Teflon interior high pressure power steering line
High pressure Earls low pressure side power steering hose
Downey 350 to 3 speed transmission conversion housing
Centerforce Clutch
Original mechanical 3 speed transfer case with hose from transfer drain to tranny fill.. I bought a new seal
So far now it’s been using a
Transfer case/ tranny connection hose
(Original ammeter doesn’t work in cosule, however the fuel gauge does)
Radio delete cover is actually a volt meter and water temp gauge area
Galvin wilderness roof rack
Galvin wilderness full length flooring
front KC daylighters off road spots
front off road lights floods
5 MB Motoring aluminum rims
5 Bf Goodrich ALL TERRAINS Ko 35 x12.5 x15- actually 4 with one dick Cepek
Windshield is from a 68, using the 2 wiper motor setup. I use one wiper motor wired up to a switch at visor, since I haven’t tried to install both to see if they are timed
I HAVE 4 wiper motors, they work and run and are about 120.00 bucks ea online when you can find them
Rear Northwest metal productsindustries 22 gallon tank
Northwest metal industries skid plate
Extended breather for rear tank as stated above
Extender breather rear axle tube as stated above
extender breather front axle tube
Original JDM front tank 16 gallon Needs reinstalled I suggest RCI fuel cell and a Secondary tank switch)
Holly blue electrical pump (mounted to rear frame by cell, you may want to mount it somewhere else
Holly external fuel regulator-set at 6lbs.
#6 xrp fuel line from pump top carb
Oil can 40 micron filter by pump. (extra filter is in storage box under front seat)
I have an extra edlebrock rpm carb 800 cfm 1910 series
Led rear back up light
Led license plate light
Safety orbital leds tipped on cb antenna(looking for RED)
GPS GARMIN Oregon 550t (on my person)
Garmin 18 external GPS Antenna.. this GARMIN magnetic mount antenna won’t mount to roof because my roof is factory fiberglass…so its mounted on the hood
Aces Netbook for garmin 18 have code for GPS Software but need laptop mount)
GPS GARMIN eMAP (extra in glovebox for passenger for hiking)
Dual cigetter light power box
3-5 gallon jerry gas cans
Cig lighter 120v invertor
Flashlight mount on tranny hump for MAGlite
Rifle scabbard can fit on roll bar between seats
have Extra orange and red side markers lenses and mountings
have Extra fender turn signals
Gropro camera mounts and
3 gopro hero cameras (older model)but not the 3d capable kind
Two extra drive shafts with loops to hold t rool cage
Interior dome LED
Under hood leds for working on truck-soon
thats just the stuff i remember
