I have finally had enough and began pushing the sled forward so I started working on my electrical system.Was lucky as hell that happened to pour a quart of oil into it just about a month ago and none of it leaked out as my rig is been mothballed for a decade. I connected the starter motor and ignition long with a fresh battery and everything I needed to get my FJ40 running minus the fuel and cooling systems --they are not yet installed. So I cranked the engine electrically to see what starter would do, and it began firing off and wouldn't stop cranking and running no matter what position the key was in, and even pulled out of the ignition! I scrambled around like mad trying to figure out what to do expecting oil to go geysering everywhere but I yanked the positive cable off the battery and everything stopped. So I'm guessing there's a problem with the actual keyed ignition on the steering column. Are these easily obtained or should I just pull the whole steering column out and replace it entirely?
