Alright guys, so, a couple days ago I was seeing how far I could get up Pearl Pass (in CO), I came across two avalanche fields still with some snow and debris. I took about 6 running starts to bust through the first one. with the last shot at it, I found there was a drainage ditch underneath. I sank up to my belly, sliders, everything. STUCK! After a couple hours of digging, I was out.
But here is the problem, now whenever i turn right i get this bad cyclical noise. It only happens when turning right with a bit of speed or pressure into the turn.
I'm wondering what this is, it sounds similar to a brake dust shield grind noise. But why would that make noise when its attached to the rotor and not moving.
My other thought is that I need to rebuild my birf seals. they were about ready to be serviced anyways. Could water/snow/pressure have worn it down faster and now it makes noise? But only when I turn right?
What is this noise, it's driving me nuts.
thanks, pics of the stuck to come
