Snorkle for FJ40
Houston TX
First let me say that I have searched the threads back over a year and mostly found info re: 60's and 80's so I will try here. I want to put a snorkle kit on my 78 40. The air filter assembly is stock. I have looked around and I think Safari is the brand I want to use.
Two questions for the experts. First, any experience with a safari snorkle on a 40? I know some have said not much performance difference. I don't plan on getting a$$ deep in water so it is purely a style over substance/I wanna look cool mod for my rig.
Second, on the MAF website it says that mods will have to be made to get it to work with the 40. Anybody know what mods they are talking about and if so how complex. I was thinking someting simple like re routing the flex pipe on there now to the snorkle tip but I may be overly optimistic.
One last question, what is the small port that is covered up with electric tape? I am guessing some type of vaccum line but just a guess.
Thanks
Thanks
The air pump(smog) inlet hose connection.
Good luck!
-Steve
Sorry that the picture is not better, but you can see where the flex tube is hooked up to this earlier style air filter housing. Some hack in Florida installed this snorkel, and allegedly "built" this truck. This poor vehicle is simply more justification as to why some people should not be allowed to borrow, purchase or use tools, ever, ever, ever, ever, fing ever.
There are other pics of this truck out here..
http://www.mindcrater.com/Galleries-2004/Gallery_23May04/pages/Maroon-04.htm
Good luck!
-Steve
Hey, if it is style over substance, just glue it to your aprons and leave everything else intact. I'm not being sarcastic here, really. I think snorkels are cool looking, so if the "look" is all you want, go for it and make the look.
GL
Ed
I have installed and run tons of Safari Snorkels on 40's, a couple notes...
To truly waterproof your Cruiser you must weld the seams on the bottom of the housing that extends out to the inlet of the air cleaner...
You must vent the drivetrain and dizzy up to the snorkel as well...
Not a difficult install, measure 7 times and only cut once through the fender...
:D
I will post some pics of my setup (79' era engine setup) ASAP...
As they say in Texas, All Hat...... No Cattle
GL
Ed
I actually thought about doing just that but I figured that if I was going to cut the fender I might as well go all the way. I do hope to get some marginal performance increase. That engine compartment is hot and the intake cant possibly be getting any "outside" air in until its heated to about 100F+.
Also, thanks Kurt for the diagram. I cant really tell but it looks like the snorkel inlet may actually sit higher than the widshield frame. Is this correct and if so do you know by about how much. I almost have to grease up to get in the garage now so this could make it a real squeaker. Maybe the top fitting can be removed with relative ease (just a pipe clamp?)
BKerr said:
...Also, thanks Kurt for the diagram. I cant really tell but it looks like the snorkel inlet may actually sit higher than the widshield frame. Is this correct and if so do you know by about how much. I almost have to grease up to get in the garage now so this could make it a real squeaker. Maybe the top fitting can be removed with relative ease (just a pipe clamp?)
Here is mine with the top on...
I actually lowered mine a couple inches, really easy to do... just cut off some of the plastic, the 3" air ram slips over the snorkel and is snugle held with a large clamp.
Hope that helps..
skyshark186 said:
What do you charge for that install?
Really depends on how much you want us to do... To drill the hole, mount the snorkel and run the hose... ? mabey $50, but it goes up from there for all the welding, etc to make it truly waterproof... I have actually had mine up over the engine, killed an ARB compressor in the process (they are great compressors, not pumps :D), the motor ran like a champ :D
skyshark186 said:
Well....if you can weld the filter housing shut on my 350 youd be a damn good welder. But thats nice to know. Gonna put in a new clutch soon, maybe ill drive it down and buy a snorkle from you and let you install it. :D
I got plenty of sheet metal... :D
Actually, not to completely hijack this thread, I would love to see what some of the V8'ers have done for their snorkel setups... We did one a couple years ago using the airbox parts from a TBI GM setup... turned out great, but it required some j-yard diving and misc. parts... If any of you snorkled V8'ers have pics, lets see em'
:D
Magoo said:
looks like you cant drop your windshield frame with it mounted though.any way around that?
Yup... We sent a couple of them off to a "plastic welder" here in SLC, they were able to bump everything out a bit, and lower the bracket so it mounts to the lower W/S hinge... thus allowing the windsheild to fold down. I remember the cost was ~ $60?
I opted not to do it to mine, mostly because I have never folded my W/S down for wheeling in this 40, I did it all the time in my older Cruiser, but lost interest... I guess I could always modify it later.
Here is a pic of one of our "modified" ones...
I plan to put one on some day and thought I coiuld just hook it up to a snorkled air cleaner. Seems like that would be easy enough.
Kurt, et al,
Since this topic got people's attention again, maybe I can post this again...not much response last week...
I'm missing the airbox from my 74FJ and am looking to install a snorkle also (but I DO intend to get a$$-deep in water). I'm considering salvaging an airbox and having a local metalshop fab up a stainless pipe and fittings with a squirrel-cage up top.
My main question is: how does ARB or other units deal with ambient water (ie. condensation, rainwater, snow, etc) drainage? Don't want to feed that to the carb!
Oh yeah, my diz is sealed and the diff cases vent to the firewall and filter already ;-)
thanks
john
yo Bj, stop pimpin that fine cruiser and get it muddy... some time late november? toolangi, maybe with some of the other 40's from outerlimits?
Kurt, youv'e got a new customer
I checked your site and I will be ordering my kit from you. I assume that the free to be customer service that I have gotten in thie thread will remain ;) . I don't plan on dropping the WS either so that should not be a problem for me.
Wish you were in Houston, I'd have you do the install for me! I guess its time to go for the full indoctrination, cutting into my rig!
Sorry to High jack thread but I do get it dirty :) ,Taken @ Toolangi a few weeks ago, yes would be interested in trip to Toolangi, catcha on Outerlimits.
Cheers Dazz
BJ, could I pleasepleaseplease get some close-up pics of the under-hood plumbing and brackets? Do you have any drainage built in for rainwater/splash collected by the scoop?
Thanks!
John
