snorkel question
I notice most of you guys put snorkels on your 100s. Why? You will never be able to cross a deep river. Just too much electronics. I would think that you would be hard pressed to get so much water in past the airfilter to drown your motors. I have extensive 4x4 experience and have only drowned a motor once on an old Ford 3/4 ton crossing a river in AK. Water was coming in the open windows and over the hood. That truck never started again.
Just a question. :)
Been in water up to the windshield wipers with deep spots rushing water over the top of the truck. What's your ride bcripe?
I have a 100. Previous 4x4s are Jeeps (cj, Cherokee, GC), Chevys, Fords, IH, Taco, 4runner. Was the rushing water actually standing or the surge? I had my old Tacoma TRD 4x4 in standing water a few inches over the wheels or about 1/2 way up the door. Water pored in from lots of areas and it was a little funny starting for about a month. Made a big mess inside. With my TLC it doesnt seem like all that good of an idea. The old Ford was so rusted out on Kodiak that often when we crossed the river we would be sitting in water. Just dont let off the gas.
BC
Yes Christo. The snorkel is eye candy for the curious.
Water type bcripe? Gila River, AZ. In the winter after snow storms in the mountains the Gila swells quite deep and for miles. White it runs pretty good it's not usually dangerous. No, I can't cross those bad AZ flash floods. Only a dummy can while he's watched floating down stream.
There are some pictures of me in the Gila when I was in the 80 along with Doron in his 100 and our buddy Scott in his Disco. It was pretty deep then too in places and we were driving up and down stream just playing.
http://www.expeditionswest.com/2003Box-Ovens/index.html
Thats pretty cool but not deep enough to need a snorkel. I was just curious about the snorkels. I sort of figured they were for looks only. I bet some arent even functional. Sorta like the hoodscoop on my old 4runner or wings on a Honda accord.
I guess if you never stop, they're not really necessary. More for "kewl" factor. But if you get in up to the hood and stall or lose traction, they can save your bacon! (Or your engine.)
I have snorkel on my previous vehicle and I hate that thing. Don't think about resale value once you put the snorkel in. I got too much attention and stupid question about it all the time. It did save the engine on a couple deep mud run when I have to make a huge splash to make it thru.
Even on that Gila River trip at the link above where you say we didn't need snorkels.......you really did. The deep spots were VERY deep and because the DiscoII wasn't snorkeled we turned around.
Doron in his 100 (pre snorkel) crossed another River in AZ that came up to his windshield(I think he said?). After the crossing he stopped ASAP and his air box was filled with water. He got real lucky. We both snorkeled our 100's ASAP before we wrecked a zillion dollar motor.
Looks like everything is o-ring sealed and pretty well in the 100. It's actually better protected than in my 80. I can sometimes get the 80 to sputter, but not the 100 (Why????).
Resale value? Who cares. I'd want $100K before I'd part with my 100. Nope, $200K. :D
(Nope, just what I paid for it so I can buy another new one! :D )
I had my truck up to the windows in one occasion (Bill Williams River) without a snorkel. Found water in the air box. This, together with the clean air rational (using a pre cleaner) made me go for a snorkel. After installing the snorkel, I found out that the Safari pre cleaner will not fit on the 100 snorkel (3” ID vs. the 3.5” 100 snorkel OD). The clean air rational without the pre cleaner is a bunch of BS. I regularly find crap in the air box that I have never had before the snorkel. More dust too. If you want dust protection, you have to use the pre cleaner. I sourced one since then.
Doron.
The baffle-silencer thingys inside the fender (that you can't see easily) are quite resrtictive, that is how they silence the in-comming air. In addition, under-hood air temps often exceed 180 degrees F. A big black tube will be hot to the touch especially on a vehicle that is parked. the air being drawn through a snorkle does not spend enough time in it to get much heat transfered. When the engine is running the snorkle body is cooler than the fender.
I have one but not because I want to go for a swim. It moves more air that is slightly cooler and a bit cleaner than what is available in the stock air intake location. This is an important, if slight, edge with a forced-induction engine.
Besides, it covers a dent in my fender...:rolleyes:
lizardking100 said:
How?
I didn't think many modern cars could have their hoods submerged w/o shorting the electronics (ignition). So even if you do have a water tight snorkel isn't your bacon cooked if you get in up to the hood?
Are you saying that you may stop, but at least you wont have water inside the engine?
Isn't the air drawn from the passenger side fender in a stock airbox?
Also I don't see how understand how the air would be cleaner unless a pre-cleaner as mentioned above was used.
Well, if you silicone up your distributor specifically for water crossings, and you protect your coil, and knowing that the ECU is behind the glovebox, then the last weak point is the intake. So, if you get stuck, and lose your bow wave, that allows water to come on in. Yes, you could stop your engine, but the idea is to be able to maintain mobility, so you can back up, engage lockers, or whatever to get unstuck.
On your second point, air up above tends to be cleaner than air down below, especially if you're in a desert convoy and the vehicle in front of you is kicking up dust. A pre-cleaner would help, but the extra weight, under vibration, can cause the snorkel to tear away from the A-pillar.
lizardking100 said:
This is the part i really don't get, if you're in a convoy on a dusty road, the 2.5 ft of additional height isn't going to make a difference. Where're I'm from the dust can go 40ft into the air and the thick stuff is at least as high or higher than the vehicle passing through it. The stockbox is sheilded from a lot of this stuff and the forward facing snorkle seems like it would get a mouthfull in this situation.
I think it'll make a difference, but that's just me. That dust originates from the ground. It disperses as it rises. Therefore the concentration will always be less the higher you go. It's all relative. I've seen the difference over 15+ years of driving in convoys in the Mojave desert. The wheels of the vehicle in front of you will be totally obscured by dust, but higher, at windshield level, you can see what's in front of you, and of course, it's even clearer at roof level, where the snorkel intake is located. And remember, you always have the option of turning the intake around to face rearward. It's just a single hose clamp.
Sure, the difference isn't huge, and this wouldn't be my primary reason to get one, but it is a nice added bonus.
BTW, our 100 Series will NOT be getting a snorkel anytime soon... ;-)
I suspect the airbox is doing exactly what it was designed to do by trapping the small amounts of water / particles that get in there. Further, since thats a low spot it probably would take quite an incline to get the water in the motor. Would the motor run completely submerged? Is it that well sealed?
Does anybody have the problem of water ingestion in heavy rains with the snorkel? When I hit puddles and small streams, a tremendous amount of water comes onto the windshield. Wouldnt it go right into the snorkel unless its turned around backwards?
Shotts, If the water was coming up to your windows didnt it come in your doors and through the firewall? Those pictures in your link must not be the deep spots then right?
Thanks,
BC
The best picture on that trip site was the video of Scott's Disco. You'll see the pass side drop into a hole and water comes over the hood.
As for pics of deep spots. Nope. We were all moving when in the water. There were no "poses" on that trip. Then, when we crossed in the 100 when it was even deeper, I had no camera. I'm waiting for a good deep shot though. Here's the best I got from a trip where a Wrangler tried to follow me through deep spots. He water locked his motor and guess who had to pull him out? The spot where I strapped him was not the deepest spot. Add another foot+?
