Here's what I've got
I guess I am trying to figure out how you would clean the filter if it was clogged without dumping coolant all over the place. The hose to the thermostat would have to be higher than the top of the radiator.
Or do you just loosen the block drain and drain a little out each time you clean the filter?
here is something else to keep in mind. Some upper radi hoses, like mine, have a spiral metal flexible support built inside the rubber hose.. so keep this in mind if your system has that as you will need to cut it, or think twice..
sor has a tendency to charge high for shipping on small orders.
I try to remember to buy "everything" in one larger order, but sometimes I forget and get stung.
Still a good shop, all things considered, but you've got to remember to game the system a little.
