smog pump
Discussion in '60-Series Wagons' started by hammer1, Aug 15, 2005.
  1. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    Got my 60 back Friday, with a new smog pump installed.
    I didnt notice it a first, but i now have a definite whistle at higher rpms, around 2k.
    at idle , its not there, but even driving, when i depress the clutch. thereby increasing the rpm's a bit between shifting, i can here it.
    i went and tightend all the hoses from the smog pump, and looked and found no disconnected vac hoses.i thought it might be the belt for the pump, since the guy didnt replace it, but its most definitely an air leak.
    could it just be the new smog pump making the whistle?
    it doesnt affect the driving, but its annoying as hell
    hammer
  2. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Well, you've got a lot more air volume running through the system now, possibly, so the increased volume coulb be finding a weak point and working it's way out, where the old pump couldn't do it...
    Is the whistling road speed or RPM based? The ASV will switch in my truck at 45mph and you can hear it start to hiss - the air is diverted from air rail on the head to the exhaust system. There's a weak hose on the ASV (sits on the driver's side fender) and that's where the hiss comes from...
    Just one possibility.
  3. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    it seems to be rpm based, since i can rev the engine and it get more pronounced. but it also come on suddenly, and i believe it IS about 45 mph. ill have to check that ASV
  4. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    what is the ASV vavle?
    i love SOR's site, since they show all the vac piping and such, but they dont show a ASV. is there another name for it?
  5. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
    things connected to air pump
  6. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    That's it - number 25710 in the diagram. Mine hisses on acceleration, and on decel, it will make a ticking sound...well, not so much a ticking as it is a rattle-snake noise, if that makes sense. Mine hisses on the front hose that connects to part number 17361 (long metal tube).
    If yours is doing what mine does, if you get under the hood and rev the motor by hand, you can hear a little bit of the hissing, then let off the revs and the hissing or ticking will get more pronounced as the engine decels. The ASV - it might be called the ABV, too...it's either the Air Switching Valve or the Air Bypass Valve (can't remember) it also switches when you decel from the air rail to the exhaust...
    Hope I haven't confused matters here...hell's bells, it's really hard to describe. Basically the air injection system works in three stages. 1) low speed sends the air into the head. 2) high speed (45 and over) sends the air into the exhaust pipe and 3) overheating cat sends air into the breather. Thing is, when you decel, it switches from phase 1) to phase 2) - if it still forces air into the head, I think it could cause backfiring and do damage to your valves. So you might be able to hear that noise more if you decel from under 45mph.
  7. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    hmmm...mine is DEFINATLEY a whistle...no hissing or ticking....
    im just wondering where to look first. i can get out my "stethascope" but when ive done that on other sounds, all i hear is the whole engine, only magnified.
  8. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
    try some soapy water and look for bubbles or drive truck underwater and look for bubbles, Either would work fine.
  9. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    FIXED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    in the above picture, it was the hose to the pump, no 17342.
    even thought it thought i had tightend both the clamps, the one clamp on the pump end wasnt pushed all the way on, so when i tightened it, all it did was clamp down on the hose, rather than the nub on the pump.
    backed the clamp all the way off, and shoved it down, tighend the clamp, TA-DA! no more noise.
    BTW, it was beuforts soapy water that did the trick!
    thanks for all the halp guys!!!!!
    hammer
  10. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
  11. Jman
    Jman
    1,550
    177
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    Word.
  12. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    + 1 :flipoff2: :D
    (and yes, plus one for me, too.)
    That friggin' valve is a nightmare though. The damn hoses and clamps are so crapped out on mine. Whomever engineered that thing needs a swift kick in the taco, for sure.
