Don't use rubbing alcohol, it has water in it. Use the denatured from Home Depot, it's diluted with methanol.
If you LEAN the mix out too much, you're going to send NOx thru the roof. You need to have the proper lean-ish mix (in a carbureted motor), not a too-lean one. You need to reduce combustion temps to reduce NOx. Too much air burns hot. Gas cools the mix.
And don't know why you're having trouble finding a CAT, they're available almost anywhere there's a parts store that can order. Just go to a muffler shop and have one welded in, if you can't find a bolt-in.
FWIW, you'll get better smog-beating info in the 60-section, as there are many more 60's that have to pass smog than early 80's 40s. The smog equip is the same as the 60s, as are the motors.
Also, how did you test the Function of the Smog Pump ?
