smelly and visible exhaust on warm days
all these HG posts have me wondering, can mine be failed with out obvious signs? there is what i am seeing:
-the truck is running hot
-the truck stinks when "cold" - not like rotten eggs but like strong strong exhaust
-i can see the exhaust come out of the muffler even on 50+ degree days.
is it time for a leak down test or what ever its called?
no loss of coolant. i will check again after some driving. maybe i just need new plugs and wires so i get better spark to burn some more fuel? running to rich? oh well.
I've got something similar. Here in LA it doesnt get cold and I get a very rich smelling exhaust and visible especially in the morning. I'm not running hot, though I have the stock gauge so its difficult to tell.
After changing the o2 sensors it got more pronounced. Didnt change at all after cleaning TB, IAC and replacing PCV. Replacing rotor, cap and plugs didnt change anything either.
Maybe yours is different, but sounds similar to mine.
valve adjustment? i have also tried seafoam. no lucky. the wife always asks, why does the truck stink?
has been holding steady... but you know it runs hot and there is the milky browness in the coolant.
but the truck runs ok.
...milky browness? That's not good. Sounds like your oil and water are swapping places. Stick your finger in the top of your radiator (when it's cooled down) into the browness and look at it... is it gooey/oily?What does the exhaust smell like? Is it kind of sickly sweet smelling? Is the exhaust that you see white smoke or black smoke? White misty exhaust is usually coolant, black smoke is burning too rich - big difference.
Time for a pressure test / leak-down test. Fill the cylinders with pressurized air and watch/listen where the air comes out.
- intake tract? - intake valves no good
- exhaust pipe? - exhaust valves leaking
- radiator bubbling? - leaking into the cooling system - leaking HG or cracked head
- oil filler cap? - oil passages breached - also leaking HG or cracked head
Get 'er done, no matter. If you don't have the ability, have it done by someone you trust.
Good luck, fill us in whatever you find. Dan.
sounds good. the bubbles! i forgot about checking the bubbles in the coolant bottle as indicated on slee's sight i think. i will check that. i know its not the end all be all test but there is a lot of work i need to get done on the truck so i might as well add the leakdown to the list.
seems like i hit 110k and everything is going to crap.
My exhaust stinks to high heaven (not sweet, just strong exhaust smell) first start-up of the day and has a white appearance for about 2-3 mins. Going to send my oil in for analysis, buy my cruiser doesn't lose any antifreeze or burn any oil at all. Is it possible they just smell in their old age?
2 or 3 minutes of steam after a cold start up seems pretty normal, especially when it's colder or humid. That said, things wear out and you might have more than one thing contributing to the smell / smoke / steam. Does your locale have a smog check? How has it been the last couple of time? Always good to check things like that.
When my son drives my 80, I sometimes observe when he drives away and check exhaust output. And if I'm any indication, things do begin to smell more in old age! :flipoff2:
Dan.
