small suspension lifts...
Utah
My 60 is saggy.
But, I also drive it a lot, and don't want to need a step ladder to get in and out of it.
I also just bought brand new OE shocks. I'm looking for something to being it up just a bit, 2" or so.. Will I be able to use the OE shocks for that?
Am I looking at just a shackle lift? Or is there a company that makes 1.5-2" lift leafs?
PO put 31x10.5" tires on it, so the wheel wells are looking fullish- I could stuff 33's under there now (33's are my goal) but then I'd look 'lowered'. I don't want that.
Maybe just some fresh OE springs and a shackle kit?
Oh, and bushings! The OE bushings are cracked deeper than the grand canyon. Will new springs come with new bushings?
Doc,
I had similar issues and just OME'ed my truck. Yikes ! Rear is definitely higher than front with the OME standard install. In the future I might modify/swap/replace shackles to level truck. Enjoying it as standard install for right now.
Had a mechanic friend of mine take lead on the job and I assisted. It's a serious job.
Cheers,
Cahil
lots of choices!
Hey Doc,
The good news is that you have lots of choices, and the bad news is that you have lots of...
CCOT/SOR/MAF all have OE height rear replacement springs. CCOT has a mild lift replacement set.
Add-a-leafs are a cheap cure for rear sagging, but some say they ride harsh. I don't have any personal experience here.
No question, replacing bushings is important - hard to remove the old ones, but this by itself will improve your handling. (Worn bushings = sloppy suspension.)
There are other options out there too, forget them all right now. Try checking the 60 tech section, there is a live post re suspension mods. That will give you some individual experiences, and product options.
Have fun on this!
here's a pic of my rig that I (with the help of ih8muders) determined has been lifted about 1"-2" in the springs. Just to give you an idea of what it would look like. As for 33"s, I would go for at least 2.5" of total lift at least for 12.5"s, maybe even 3" just to be safe. I suppose I could fit 33x12.5s in my rig as is but they would probably rub. I plan on getting some extended shackles before I go for 33x12.5s. I hear 33.9.5's fit under stock springs though...
oh, and its riding on 15x8 wheels and 31x10.5s.
keep in mind that if it is sagging even a small lift will yield more than you think.
i put a 3" lift under mine, and i truely believe that raised it 5(five) inches from the sagy state it was in.
before:
after:
CCOT=?
I'm not up on my anacronyms.
Is there any particular reason to not use JUST a shackle kit to get my lift? (geometry changes, etc?)
Can I buy bushings seperate from a lift kit? Energy suspension polyurathane perhaps? I'm not worried about getting them out, they will either crumble upon dissasembly, or a torch will be employed. I replaced every rubber bushing on my little Honda with Poly busings from energy susp. so I am not unfamiliar with their work.
VTcruiser, how did you get a 2" lift under there? Are there new springs, or just new shackles?
CCOT = Cool Cruisers of Texas
I am not sure the make of the springs (sorry, meant to mention that) they were there when i bought the truck. They look old though. The PO (previous owner) said he thought it may be lifted some but i was skeptical at first but didn't care (it was the diesel i wanted). Afterwards though after seeing other stock 60s, i decided it must be lifted and took some measurments. The shackles are stock length, so its in the springs and probably around 1.5".
EDIT: Also, Bushings are often sold seperately and a torch is a common method of removing teh old ones. As for using shackles alone, there is a limit to the length they should be. Its fine to use them with stock springs but they may not provide must lift over stock "unsagged" height.
