I am chasing down a small radiator leak in a '97 fzj80. The leak is coming from the bottom; the underside of the bottom tank is wet. The system leaks down about 3 psi an hour at 7 lb. At 14 psi it leaks down about 1 psi in 5 plus minutes. It is not the bottom main hose, it is dry.
This has apparently been consistent for the last few months. I noticed I had to replace fluid in the reservoir every month or so.
1. Is this likely a radiator failure or is there something else down there that can leak.
2. The fan shroud looks at though it is held in by bolts at the top and slide in clips at the bottom. Is this correct. Thanks Dan
