Wanted sm465!!!
Welcome.
Where are you at?
Are you willing to drive to Minnesota for it?
Let me know.
THANKS!
-Steve
I have a couple in WI, but i'm sure shipping wouldn't be worth it.
Any recking yard will have them, I got mine for 80 bucks. If you are using a cruiser Tcase get a 2wd version they have a 35 tailshaft.
pbgbottle said:
why 2wd just curious
35 Spline tail shaft VS. 10 spline
pbgbottle said:
i thought with the cruiser t-case the 10 spline was more desirable , any more info to offer up . on how to use the 35 spline with the cruiser case plate adapter or AA 5 inch long adapter
The 2WD output shaft is extended and threaded to hold the ujoint flange. You have to cut it down to get to the 35 spline section, which the AA spud shaft fits.
The 4WD version doesn't need the output shaft cut down AFAIK.
So I guess the 35 spline might be stronger but a little more trouble to adapt. I cut mine down on the radial arm saw in less than half an hour - not a problem.
i thought you new something else i was missing , i too have the 2wd version that was why i was curious why you reccomended it , i left my tranny in the engine stand held a 5 inch angle grinder up to it and had someone slowly turn the main shaft ,cut it off in a few minutes , sweet if i was to do it again i would swith to woodies one inch plate adapter using the 4wd version main shaft ,so as to have a longer rear drive shaft , i see what you are talking about, about the 2wd being stronger , fine spline , i never thought about it , also wanted to add , i have never had an issue using this setup with AA 5 inch long adapter ,
later Jake
