SM465 w/mini truck t-case adapter (1 Viewer)
Fresno, CA
Ran this stuff for a bit in my FJ60 and it all worked fine. The 465 is setup to bolt up to a 3 speed bellhousing with the nose cone already modified. There is a shift handle that I used in my 60 that has the upper portion of the H42 handle welded to the lower portion of the SM465 handle.
The adapter includes the input for a 4.7 gearset, you would just need the counter and low speed gear to finish it off.
I only pulled it because I threw a new setup in.
I'd like to get $250 pick up or I'll ship for $300 for the trans and adapter.
Boise, ID
Damn you and your bigger tires than me :D. I'm working on downsizing my current tires, if any $ comes out of that I might pick up your trans. I'll let you know.
TLC Norway
woodwelder
North of Norway
i am still soo confused about the different options for my hj60.. h42 and 2h.
this will not fit, right? suggestions? i wanna go lower and slower...
i guess your new setup is the s***, but i am not capable to do the same job!
