I'm thinking about running an sm465/toybox/splitcase behind a tbi 350 in a fj40 and was wondering if anyone has any input. Will the toybox hold up with a v8 or is there a better solution?
Do you drive it on the road also or is it just a trail rig? The reason I ask is because the rig I'm building will be my sons first vehicle and will be driven daily.I have been running the SM-465/Toybox/3-speed since Dec. 2003, behind a Chevy 350 CID engine, and have not had one problem with it. I'm running the Rubicon, Dusy, Fordyce trails every year, so not exactly babying the drive train.
Most of my trail use is with the Toybox in "low-range" and the transfer case in "high-range).
go to you tube and look up "last man standing hollister 2010" and you will see what my fj40 with a fuel injected 5.7L with a SM465 and a Marlin crawlbox with 2.28 gears and the stock transfercase with 4.10 gears on 37" Boggers and a big right foot. I love the setup and dont have any problems, I think its a great set-up
How far back did you move the rear axel to make your setup work? The way mine is set now its pushed back 4" and I still have the option of flipping the springs to get more if needed.Crwlntoy..... you asked if I drive my Cruiser on the road?? You bet! I drive it to most trails. In fact, I drove it to Moab and back a few years ago.
For your info.... I have the 4.7:1 ratio, and it is the cat's meow. 1st gear is sometimes too low (even with the transfer case in "high-range", so I frequently use 2nd & 3rd gears in the tranny which are synchroed. Works very nice. Quiet on the highway too.
After watching your videos it is obvious that it is a stout setup. I hope my son doesn't try to drive like that after I show them to him.go to you tube and look up "last man standing hollister 2010" and you will see what my fj40 with a fuel injected 5.7L with a SM465 and a Marlin crawlbox with 2.28 gears and the stock transfercase with 4.10 gears on 37" Boggers and a big right foot. I love the setup and dont have any problems, I think its a great set-up
I have not moved my rear axle back; nor have I flipped the springs. The rear driveshaft is about 19" long with a double cardon joint. This setup is liveable, but probably not the best.
