sm465 throw out bearing
Cloverdale B.C. Canada
Website
www.instagram.com
hi there ,just wondering which throwout bearing you guys are using with the small block chev and sm465 toyota slave (1978) the one i have is not the same lenght as either of the two choices from lordco ONE HAS A SHORT HUB ,THE OTHER HAS A LONGER HUB ,AND THE ONE I HAVE IS RIGHT IN THE MIDDLE .EITHER I HAVE TO LOOK FOR A NEW BEARING AND PRESS IT ONTO THE HUB I HAVE .OR GO WITH ONE OF THE 2 RECOMENDED ONES . ANY INFO WOULD BE GREAT ? PART # .USING A CHEV LOW CONE DIAGHRAM TYPE PREASURE PLATE .
jAKE
I used a stock GM bearing, no clue which one offhand, just make sure you use the CAST clutch arm and not the STAMPED steel one. (see my writeup on the install)
use the bearing for the bellhousing...alum bellhousing is the later throwout, cast bellhousing is the early throwout.
