- Location
- United States
Have a 60's sm420 mated to the lower geared 3 speed t-case using an advanced adaptor (older style). I also put in an adavanced adapters output shaft seal retainer (tranny to motor) https://eshop.advanceadapters.com/co...520-712520.htm which you see is $200 alone. Front ouput seal will need to be replaced. The chevy bellhousing you see on it will not come with it unless you need it cause you use a 3 speed LC bellhousing to adapt it to a f/2f. It also has a '74 manual stick shifter setup (not pictured) with it which is rare and hard to find (paid $100 for it) but I can put the vacuum shift arm with it if you need it. The tranny is currently in my cruiser but I have not ran it (the PO stated "it was fine" when he pulled it, but you know how that goes), the picture is before I put it in. I was going to run it as is but now decided to put in a 700r4, Dana 300 combo.
$350
$350
