sm 465 i think
i recnetly bought a tranny out of a 1984 2/4 ton chevy. i believe it is an sm 465. this pick up was two wheel drive, because of this there a piece coming out of it closly resembling the third memeber on many common axles. my question is would it be best to run a small drive shaft to a divorced tranfer case. Or is there a kit out there that will change that piece into an out put shaft which then can be adapted. if anyone has any inforamtion at all it would be very help full. i have the numbers as well if anyone can verify what it is.
merc :cheers:
if you opt to go the plate route, pm me in a week or two on the plate...I'll have some alum ones available, including a stud kit.
no...for the 5 bolts that hold the t-case onto the plate...my alum adapter is setup to use 1/2"-13 studs, 3 LONG ones, and two short ones....
Also uses 8 Torx bolts to attach the plate to the tranny.
This pic is the prototype installed in my truck now....finished one will be shaped similar to the black lines on there.
Soooooo,
What are you doing with the output shaft of the 465? Welding a stud to the end of it, or having it drilled and tapped? I have read your write up on it, I can not remember which path you took...
Thanks for the pic!
PM me what you are looking to get for a few of these...
Thanks!
-Steve
I'll be running one more trip, CM04, then releasing a batch to the machinist. This is the first time I've had this adapter and not had it leak after the first trip! lol
I had my output tapped...but I'd get a stud tig welded on next time. IMO, much easier and equally secure.
You do need to run a 1/2" bit thru the 5 holes that these studs go thru...I believe two of mine actually removed a skin of metal...the stock holes are far from perfect.
I used the AA crossmember...would design something else now. I modded my cross to plate off where the hat went, and did a stud kit in the t-case so I could get a little torque on the bolts. Never have liked it tho...just been too lazy to design something better...
The 2 wheel drive sm465 has fine spline output, so the plate adaptors won't work unless he changes the shaft. I wish I would have gone that route. Instead, I cut the threads off the output shaft and used the AA adaptor. It works fine, no problems, but like you say, it's over 5" long.
[quote author=theo link=board=1;threadid=14364;start=msg135190#msg135190 date=1081444502]
[/quote]
This is one of the reasons why I suggested the Classic Cruisers adapter set up, as it includes a modified main shaft to replace the 2wd version that he has...and the fact that it is far shorter than the one offered by AA.
Good luck!
-Steve
[quote author=Poser link=board=1;threadid=14364;start=msg135275#msg135275 date=1081451919]
[/quote]
Just wanted to give Merc a heads up, in case he started thinking Woody's plate would work for him without changing the shaft. This is just the sort of detail that can trip me up if I have lots of other stuff to think about. Drive myself nuts on a regular basis! :)
Further,
Even if he had a 4wd version, the output shaft would need to be modified, either by welding in a stud, or threading the shaft to keep the tcase input gear on...
Good luck!
-Steve
