Sluggish Starting
I have a 4 year old rebuilt chevy 350 that just passed smog with flying colors. I just replaced the sparkplugs, air filter (K&N) and fuel filter.
Everytime I start the truck after a day of sitting I have to depress the gas pedal for a few seconds while it cranks , release the pedal, then keep it cranking and finally it kicks over after maybe 15-20 seconds. Once the car is running if I shut it off , head into a store for a minute then return, it will start up with out depressing the gas pedal.
Does this sound like a tired fuel pump? The filter is still crystal clear with fuel in it.
Sounds to me like the float bowl is leaking fuel into the engine when it sits for a while...If it operates fine after start up, I would not think that the fuel pump is the issue here...
This 'krystal kleer' fuel filter.....where is it located? Before the fuel pump, after the pump? Just in front of the carb, or down by the pump?
Good luck!
-Steve
I agree with Steve it sounds carb related. I am assuming its a carb and not Fuel Injected?
mine does this too. I have a 74 fj40 with the 4 motor and a rochester carb. when its warm out sometimes it will start fine.
sorry ment the f motor
When its cold, the choke doesn't take care of it? I notice on my stock 2F that I need the choke to start when its cold or cool and when it is hot, I don't. When its cool or cold once its warm (couple of minutes) i can take the choke out and it runs fine. I believe thats normal.
It does start with the choke... But it cranks for quite a while b4 it starts. almost seems like its building pressure. and you can hear a faint noise
kinda like a hissing but not quite, sorry about the description but its weird. I do have a complete 2f from a 78 and that starts great i was thinking about swapping parts to make mine start better. I know the carb would be a good choice but what else would i want to swap...
My fuel filter is located before the fuel pump. Checked it again today and it's full of fuel and still looks very clean. I've not disected a carb before, so when you say the fuel bowl may be spilling into the engine, is that something that would require a carb rebuild? An adjustment? I need to check and see if the choke linkage is still hooked up.
