She usually smells rich.You might try sniffing the exhaust right after it starts to see if it smells rich or (not rich).
I wonder if your cold start injector is firing on hot days as well as cold.
When the engine is hot and has trouble starting you could try disconnecting the cold start injector to see if it starts any better. Could be that the injector is running when not needed. Its probably not the issue but its easy to try
Oh. Thought you were saying it starts poorly when the engine is cold but it’s hot outside.
that’s right but in your last post you said ‘when the engine is hot and has trouble starting’.
The truck has trouble starting when the engine is cold/has been sitting for several hours or longer. It’s noticeably worse when the air temperature is above 90 degrees.
thanks for all your help by the way. It’s definitely given me a for more things to check.
