Trying to chase down this leak. Like the title says gas is leaking from the fuel fill area fuel but only on a full tank. 3/4 fill doesn’t leak at all and have been going like this all summer until I could get to it now before winter hits. I’ve been searching the forms but haven’t seen anything much similar. Perhaps it’s a gasket? 2006 LC.
I’ve attached a picture and you can see one drip a stringy streak which is actually the gas dripping in motion. It is hitting the stabilizer bar if this helps to get a better idea of where it may be coming. Mind you, this is taken on my driveway which has a 20° or so slope.
The yellow area I’m pointing out shows an area where some gas maybe leaking down as well. But the only slow drip comes from the area onto the stabilizer bar.
Hoping I can just get by on a gasket and if so that it’s relatively painless.
[Maybe just another matter , but the tank does have some flaky rust on the protective coating. Also some crusty seams around the top where the lower portion of the tank meets the top portion. I be been treating the rust with fluid film over the years and seems to stopped the spread ]
