I'm putting some sliders together with some steel i had left over from previous projects. The main tube will be 2"x2" and 1/8" thick. The outriggers are schedule 40 2" pipe. My truck has AHC and I do plan to leave it in so these mounts have to fit around that, I couldn't find any good photos showing how the other sliders mount around AHC ,but I figured out i could get 2 compression mounts in there on each side. Here is the photo of the mount. It's 1/4" and I will secure with 2 grade 8 1/2" bolts.
This is the mount toward the rear end, the ones up front are more open, but the connection to the main bar will have to sweep back at a slight angle because the frame angles in toward the engine.
Are 2 mounts enough? I won't be slamming this thing on rocks constantly but I do want protection. This is sort of a "quick and dirty " slider build before I head up to Windrock next weekend. I will eventually build some exactly like I want and just weld them in more than likely.
I want to angle my pipe out riggers up about 15 degrees but I can't for the life of me figure out the cut so I may just go straight in.
