BenMara
Asian Redneck
for the tire size question
enough pics?
enough pics?
enough pics?
I am running 37's on mine "out of the box".
"In the box" means things like running mud flaps
Once you get the arms on be sure to torque to spec. HOW MUCH GUYS? 150? We heard some minor knock noises at first. Did research and re-tweaking the arm nuts stopped that.
I'm in Houston as well. PM me if ya want an extra hand. Done a few lifts on different trucks here at the house and would'nt mind seeing the Slee kit. Let me know
Tommy
When I went from the J lift to the 6"...all I did was take out my J coils....and put the 6" coils in.
If you threw down the full price for all the other parts...you'll have a more things to turn bolts on, but all I changed was the coils.
Now I'm going to try the same thing with these....and set a stopwatch to time when things explode.
Depending on what other work you are doing at the same time it may be easier to pop out the axle. When I did mine the front axle was pretty much completely gone over (wheel bearings, new TRE's, rotors, pads, calipers rebuilt, seals, felts etc.) and it was much easier to do on the bench than under the truck. A FSM, air tools and a decent torque wrench are your best friends.
Where do those clear front indicator lenses come from ?
I need a set for ROOBY.
Codyrx7, where did you get the coils from? and you did not change the control arms? What about the panhard? Adjustable I am guessing?
A little late on the scene, I know. Everything goes together pretty smoothly but it is work and it is time consuming. It sounds like the you've already taken care of the biggest pain, brake lines and bleeding. Next to that I recommend a good set of brass punches and hammer (there are alot of parts to allign). If you run into any specific problems, PM me.
Biggest tire size is completely dependant on location and wheeling habits. I run 35's and rub all of the time, even with no mud flaps. I still keep waiting for the money tree to sprout so I can get my 37's though
Done. Had to work around my schedule to do it. Two to three hours a day for several days did it. How did you all torqued the bolts on the DC shaft flange? I just have enough room for a closed end wrench. Thanks to all the guys who offered their help.
