Slee vs OME bushings (come give your opinion)
Kansas
I have made up my mind, short of ordering some sort of better radius arm setup ( I think superflex is the only option) I am going to use caster correction bushings and ditch my old Man A Fre drop plates. The plates that go on the axle side are tempting but I don't want to spend that kind of money and don't feel like drilling. So now I need some opinions on which ones are better or have worked for you guys.
Obviously there is the OME yellow caster correction bushings. Then there are Slee Hi-Flex bushings. I have not heard anything about the Slee bushings but am interested to know if anybody here is running them.
FAIL---- they are out of stock. But less than half what the others are charging makes them appealing to me. Are you running them on your rig ?
I'm sure they are available from another vendor. I only posted the link because people are unaware they are even available in rubber. Yes, I'm running them.
Found them from a place called Big Country Customs (sounds suspect) but for $75. I would think the rubber would flex a bit better then the poly bushings, I could be wrong, I'm no suspension guru.
Slee's 3* caster bearings look pretty sweet and they're $15 LESS than his bushings!
Why? Have you ever even held the TJM's?
$135 for a set of caster bushings is :censor:.
Nope and I don't care. I've used Slee's multiple times and they have performed great. My time and reputation is of value to me and that is my recommendation if bushings are the only consideration. The OP asked for opinions and that is mine!
I believe turbophil has a set of caster bushings he bought and then went with drop brackets. If you haven't ordered any can't remember which brand.
I'm pretty sure the Slee bushings are made by Whiteline.
I'm pretty sure, too.
Big Country Customs is a legit shop, I would have no problem ordering from them. FWIW, I have no affiliation, but have heard really good reviews
