Africaster
Hi All, the front pair of the Slee kit doesn’t have a small extension that seems to be for a guide pin on the calipers … install and don’t worry? Appreciated Brad
One is the flex line between the rear axle and the frame mounted brake line and the other (from Slee's website description) is something to do with VSCMy '07 had the Slee brake lines on all four corners when I bought it. Where do the other two lines in the kit go? My line going to the rear axle is OEM and it sure would be nice if it was longer to simplify swapping coils.
The 98 to 00 design (5 line kit) shows the rear axle to frame hose, that hose is in the 6 line kit, but the additional line and the listing specifies VSC vs Non VSC.Thanks! Where are you seeing that description?
SLEE Brake Line kit - '00-07 Land Cruiser / LX 470 (With VSC) - Slee Off Road
6 Line Kit 2x Frame to Axle lines extended length (+3") for longer aftermarket shocks DOT approved Supplied with clips and washerssleeoffroad.com
