Slee Spacers
huddleston
GOLD Star
Fayetteville, AR
Installed the 150mm spacers when we did the icon/nitro/OME install and I feel like these stick out more than what I have commonly seen.
Tires are 295-70-17 Toyo R/T’s.
I know I can remove them but then I believe my the center caps won’t fit on my icon wheels.
Is this much tire outside the fender common for these spacers?
What is the offset of your wheels? I bet It’s probably somewhere in between 18-25mm. Usually not a good combo with the spacers.
25mm offset.
Looks like I should take them off. Will I need to buy new tires as well?
No need to buy new tires. Just ditch the spacers.
I run a 295/70/18 on +25mm wheels. Tires are the same width as yours just around 1” taller. Width should look good, nearly perfect IMHO. Here’s a pic of my 295s on the +25 wheels.
