I installed a Slee Short Bus bumper on my '96 FZJ80 today, and figured while I had the time, I'd take some pictures and spell this out for anyone who may be considering an install. This is my first write-up on a tech article (except for my wiring short story a few months back), so have patience.
Solo Wrench - as I was on my own for this one - but still rates 'Easy' on the hard work and difficulty meter, and working alone and taking pictures I finished this in about 3 hours. Adding friends would shave about an hour or more if you're trying to beat my qualifying time.
Cuss-Factor of 'Zero' (*and I spent some time on the USS Tripoli - LPH10!), , as everything is straight forward and well-built to fit as designed.
Here was my starting point;
The Slee Short Bus (SB) bumper comes well-protected with both foam sheet and heavy plastic bag inside of a cardboard box. I dragged this home from Overland Expo in the back of my Mazda6s Hatch minus the cardboard, so while a bit unwieldy, it's not very bulky to transport. Included were the full hardware set containing the upgraded fasteners, but no instruction sheet - but installation is so simple, you don't really need them except for the torque specs.
Tools you will want to have available include the following;
* Hammer!
* Multi-driver for tightening the fairing fittings and such
* 14mm Box-End for removal of the stock bumper
* (optional) bristle brush for cleaning off 15+ years of grime/dust/bugs
* 17mm Socket for stock recover point removal
* 19mm Socket for installation of Slee hardware
* (not shown) 19mm Box-End for installation of Slee hardware
* (not shown) Torque wrench to fit 19mm and 17mm sockets to install Slee hardware
* (not shown) Wheaties and milk
After removal of the stock bumper, I decided to do some general cleaning and make sure everything was tightened up, brushed out the A/C evaporator and Trans Cooler of years of dead bugs, and used a sheet of cardboard as a mask while I sprayed a quick coat of black to cover up the now-visible front end components which the stock bumper hid nicely and the Slee SB exposes;
In the photo above, you can see that the stock shipping tie-downs are still attached, and they need to come off to install the SB. You could probably bolt through them and keep them, but after considering this for a bit, I decided to leave them off, as the Slee designed recovery points are plenty for the kind of driving I tend to do.
The SB bumper weighed in at 92.8lbs, and I was able to muscle it into position (*twice, including the weigh in) through my novice 'power-lifter' stance and a breakfast of Wheaties. Slee advertises this at "slightly less than 90lbs", and it probably varies a bit due to welds, material weight, etc. Compared to the stock bumper, this thing is hell-for-stout, for only about 3x the weight.
Slee-provided fasteners are good quality bolts matching the factory bolt points and thread pitch - no nuts are needed throughout, making for a very straightforward installation. The bolts shown here are roughly in position per side, as I like to lay them out, ensuring all the parts are there and in order before I start bolting things together. It sucks to find out that bolt you just spent 30 minutes turning in 1/16 turn increments is missing it's lockwasher!
(*the collection of bolts/washers at the top are for the front license plate frame, which I didn't need and were added to the spares box)
I sprayed each bolt down liberally with a penetrating lubricant along with the threaded frame points, and it all went together easily.
Keep reading Part 2, below if you're still interested and want my impressions after installation...
* Hammer!
